Reduced engine power
Old Jul 23, 2025 | 04:56 AM
dpwill918's Avatar
dpwill918
10th Gear
Default Reduced engine power
2019 Lexus RX 350 been chasing and Evap leak for a while, small and large leak codes are popping up. I have been clearing codes after trying fixes and before going on trips. The low engine power light has come on twice but only while the large and small evaporator leak codes are present on the ecu. Not sure if the Evap leak has anything to do with the low engine power light coming on.
Old Jul 23, 2025 | 05:23 AM
jcg0324's Avatar
jcg0324
What fixes have you tried? Did you try replacing the gas cap? I would go with an OEM cap if you do.
Old Jul 23, 2025 | 08:52 AM
dpwill918's Avatar
dpwill918
10th Gear
I have replaced fuel cap along with mechanic replacing my replacement. Had a spot where a rodent chewed on a vent line by the fuel tank had the mechanic repair and still getting the Evap codes. I am not too concerned with the Evap issues as I am with the low engine power light coming on.
Old Jul 23, 2025 | 04:27 PM
N4TECguy's Avatar
N4TECguy
Anything throwing EVAP codes with actual drivability issues, I would lean towards a purge valve issue.
Old Jul 24, 2025 | 08:52 AM
supratreo's Avatar
supratreo
has you mechanic done a smoke test?
Old Jul 25, 2025 | 12:59 PM
dpwill918's Avatar
dpwill918
10th Gear
yes two different mechanics replaced the purge valve so it’s been replaced twice
Old Jul 25, 2025 | 01:02 PM
dpwill918's Avatar
dpwill918
10th Gear
I was told by my latest mechanic he has done smoke tests. First one has cap and second re repaired the vent line rodent repair
Old Jul 25, 2025 | 01:05 PM
dpwill918's Avatar
dpwill918
10th Gear
Again at this point, I don’t really care about the evap leak, but I am concerned with getting the check engine light with the low engine power light.I’m wanting to know if by having the evap leak tripped on the ECU is it more likely to come up with a check engine low engine power light?
STG1301
NX - 1st Gen (2015-2021)
Apr 23, 2025 08:10 PM
rmk9785e
RX - 1st Gen (1999-2003)
May 29, 2023 02:29 PM
akonful
RC - 1st Gen (2015-present)
Jan 4, 2022 04:57 PM
Joeb427
Performance
30
Mar 17, 2008 05:53 AM
