Single click While driving
Old May 17, 2022 | 12:10 PM
Alexbenz's Avatar
Alexbenz
Default Single click While driving
i hear a loud single click noise when driving, first i thought it was when i left off the brakes and then maybe when i was turning but can't seem to figure it out. Anyone have this before?
Old May 18, 2022 | 06:13 AM
Louczar1's Avatar
Louczar1
Does it happen when you start to give it gas to get going? Or are you already moving?
Old May 26, 2022 | 02:27 PM
Alexbenz's Avatar
Alexbenz
both, I'll come to a stop and then go in reverse and I hear it and once I get moving and take my foot off the gas I'll hear just a single click
Old May 27, 2022 | 04:39 AM
Clutchless's Avatar
Clutchless
That could be (and I suspect is) as simple as brake pad movement clicking and nothing to worry about. They shift position during these movements and due to the quiet you can hear it.
Or (less likely) a worn CV joint, so the axle boots should be inspected for tears and leaks.
Old Jun 1, 2022 | 10:29 AM
Alexbenz's Avatar
Alexbenz
i figured it was something with the brakes as i need them done very very soon. thanks man
Old Oct 4, 2022 | 06:53 PM
Alexbenz's Avatar
Alexbenz
sounds still there, guessing it's the cv joints or something along those lines. Guess i'll get it checked with the next oil change
Old Oct 5, 2022 | 04:08 AM
Clutchless's Avatar
Clutchless
Even new brakes can make this noise when you reverse, stop and then move forward. It is very common and not an indication of a problem. Now the brake guys may have negected to install all the pad shims that reduce that noise, but if not a self help mechanic then you need a shop to check it out.
Or it could be a CV joint. Look for torn boots and grease leaking around the axles and inside the wheels/tires/brake calipers as it gets flung all over the place. But if you just had your brakes done then the shop would have noticed any problems with your CV joints.
Old Oct 7, 2022 | 10:36 PM
Alexbenz's Avatar
Alexbenz
good points, Doubt it is the brakes since it was making the noise prior to the rotor pad replacement. I'll take it in again and have them check it out.
dmichael
RX - 4th Gen (2016-2022)
Mar 21, 2018 06:28 AM
Macgyver
Oct 3, 2016 08:51 PM
I8ABMR
IS F (2008-2014)
Oct 3, 2014 07:38 PM
the90zkid
Suspension and Brakes
Jul 22, 2010 08:01 PM
xknowonex
Maintenance
Jan 31, 2008 09:34 PM
