Fuel filter replacement
I知 thinking of replacing my fuel filter on. I知 having a stutter when accelerating around 20 to 40 mph. Think it may be a fuel issue thought I start with the filter. Has anyone changed theirs on there own. Where is it located?
The odds are it is more likely to be something else other than your fuel filter. They are rarely replaced unless the fuel pump or gas tank needs replacement. It is inside the gas tank and you get to it by removing the rear seat cushion to access the top of the tank.
You should do some actual diagnostics before replacing random parts. What year and how many miles are on your RX?
Try running a bottle of Techron Fuel System Cleaner through the gas, get the larger size bottle. Almost every auto parts store sells it. Give a couple of weeks to work.
While at the chain auto parts store ask if they can check for any stored codes that may be indicative of the source of your stutter.
I have a 2013. I put in a bottle of fuel injector cleaner. Put about 70 miles on it. Haven稚 felt the stutter yet
