RX 350 glove box removal
Old Jan 22, 2020 | 05:58 PM
Kkelly311's Avatar
Kkelly311
Default RX 350 glove box removal
Taking the ECM out and am stumped on the glove box removal. The airbag is the question .... how do I get it off to access the lower screws on the glovebox?There is a plastic rectangle trim piece over the airbag .... does that have to come off or are there some bolts underneath that holds the piece on as a whole?
Old Jan 22, 2020 | 07:34 PM
mtellup's Avatar
mtellup
This is a CarPlay install video, but it shows how to remove the glove box in a 2013-2015 RX350. The glove box part starts at about 3:45.
Old Jan 22, 2020 | 08:30 PM
Kkelly311's Avatar
Kkelly311
outstanding! Huge help. Great find.... TY
Old Jan 30, 2020 | 08:26 AM
Kkelly311's Avatar
Kkelly311
glove box is easy to remove, however, in ECM is not behind it, it is under the hood for anyone who finds this and needs to know. The toughest part on the glove box is the far left airbag bolt and black glove box phillips head. The vertical trim piece of the console side has to come off and you will easily see the two fasteners. There are (3) 10mm bolts for the airbag and (5) small black phillips head screws for the glove box. There is an electrical connection or two to the glove box so be careful pulling it too far outward without disconnecting.
Old Apr 19, 2023 | 12:36 AM
JohnK005's Avatar
JohnK005
2nd gear
Default RX 350 Glovebox door removal instructions or how to video.?? URGENT PLS HELP ASAP
How to remove glovebox door to re apply vinyl as mine has been damaged. I need to redo the vinyl layer and can't find instructions or a video anywhere for a 2013 RX 350 on removing the glovebox door only.
leonrojo18
Jul 19, 2021 06:06 AM
GThornton
RX - 1st Gen (1999-2003)
Dec 13, 2012 11:27 PM
ihiryu
Jul 28, 2012 05:02 PM
lovemov
Jul 30, 2004 10:17 PM
thao94
Oct 31, 2003 01:45 PM
