Awd, check engine and traction off
These lights came on last night. Is there a sensor or a way i can check them? I had my oil changed and new brakes and rotors placed a week ago. Would this be affecting the issue?
OBDII scanner can read the codes for you. Many auto store do this for free.
Salim
Salim
At a guess, one of the ABS sensor wires or some other braking related sensor may have been disconnected of damaged as a result of the brake job last week. But yes, knowing the error code would help narrow down the issue considerably.
This happened to my first generation after a non-dealer oil change.
They checked my air filter and in the process inadvertently unhooked a hose underneath.
Same lights as mentioned.
whoyouknow
12-13-18 12:26 PM
