Can the tailgate be partially closed?
Old 01-17-18, 10:29 AM
Skier76
Skier76's Avatar
Default Can the tailgate be partially closed?
We may have to haul some kayaks this weekend (long story about an ice jam) in our 2013 RX 350. Is there a way to partially close the tailgate so we don't have to drive for miles with it wide open?
Old 01-17-18, 11:47 AM
paperthin
paperthin's Avatar
Yes you can. I have used bungee cords to partially hold it down when hauling lumber, and even a treadmill in the vehicle. Off the top of my head I can't remember where I hooked onto.
Old 01-17-18, 01:51 PM
salimshah
salimshah's Avatar
Not recommended.
You can get exhaust fumes back inside the cabin .. silent killer.
Structural strength is drastically reduced.
For short trips it might be ok, but not for miles and miles.
Salim
Old 01-17-18, 02:14 PM
ISFLexy
ISFLexy's Avatar
while on this subject, is it possible to lift it up manually, without using the auto feature? I find that when its parked in the garage, the rear hatch opens up so high it nearly hits the garage door, but if i can manually open it just enough to throw something in the back i'd prefer that way much better.
Old 01-17-18, 02:50 PM
Clutchless
Clutchless's Avatar
Received 1,098 Likes on 937 Posts
Yes, I open mine manually most of the time because I am inpatient or do not have my key as it is in my garage. Auto feature still operates perfectly.
Old 01-17-18, 03:51 PM
Airbalance
Airbalance's Avatar
Originally Posted by salimshah
Not recommended.
Salim
That is 100% correct
Old 01-17-18, 06:32 PM
salimshah
salimshah's Avatar
I see no problem in opening the hatch manually.
Salim
Old 01-18-18, 06:53 AM
Clutchless
Clutchless's Avatar
I did once haul a 15 foot kayak inside the RX with the hatch held partly closed with a bungie cord. I set the passenger front seat back as far down as possible covered it with a blanket and put the kayak inside. Tied it to something to keep it from moving. I only hauled it about 4 miles on local roads.
Old 01-27-18, 02:36 PM
Skier76
Skier76's Avatar
Followup: Worked fine. I used some bungees on the hatch anchor points. Finding a spot on the actual hatch was a bit of a challenge. I ended up hooking the bungees to the hatch liner, by pulling it out a bit from the hatch. Not ideal, but when in Rome..... Worked fine and no issues. Aside from the really annoying beep we had to listen to all the way home. Thankfully, it was just a few miles.
Old 01-28-18, 07:19 AM
Randyp1234
Randyp1234's Avatar
How do you do this?
Old 01-28-18, 07:37 AM
salimshah
salimshah's Avatar
Originally Posted by Randyp1234
How do you do this?
To open manually:
Feel the release latch above the license plate. Give it a squeeze to release the latch and lift up the tail gate.
If you have the key on you, all door locks will unlock [your settings may be different]
The hatch close can be done manually too.
Salim
ps: Open the hatch as you currently do and you can visually see release next to the rear view camera.
bam
RX - 3rd Gen (2010-2015)
47
06-26-12 08:04 PM
yeehawbob
Hybrid Technology
06-04-12 02:05 PM
runscissor
Hybrid Technology
02-17-10 10:25 AM
drpack
11-29-03 07:52 PM
Quick Reply: Can the tailgate be partially closed?
