2013 RX350 Alarm Chime/Beep Volume
Old 01-01-18, 05:44 AM
Skier76
Skier76's Avatar
Default 2013 RX350 Alarm Chime/Beep Volume
Recently, I noticed the alarm chime was really quiet on our RX. We hadn't changed any settings, so I wasn't sure why it suddenly got really quiet. I went into the settings via the nav screen and confirmed the volume was set to the highest setting. Still, hardly a sound out of the system.
Any ideas? It sounds very muffled. Similar to how it sounds if the windshield cowl is covered in snow. I checked the area and there are no leaves or other obstructions.
Old 01-03-18, 12:46 PM
Skier76
Skier76's Avatar
Anyone know the exact location of the module under the cowl?
Old 01-17-18, 10:08 AM
Skier76
Skier76's Avatar
Anyone? The chime is practically silent at this point.
Old 01-17-18, 10:11 AM
Clutchless
Clutchless's Avatar
Received 1,096 Likes on 935 Posts
You could find the part at Lexus South Atlanta parts web page as they have exploded drawings of everything so maybe that would help you locate it. They would be a good place to purchase it from.
https://www.lexussouthatlantaparts.c...car-parts.html
Skier76 (01-17-18)
Old 01-17-18, 10:26 AM
Skier76
Skier76's Avatar
I think I found it: Part number: 89747-30040 It looks like it's located behind the fender based on the diagram : https://www.lexussouthatlantaparts.c...category=21749
But from what I hear, it sounds like it's under the windshield cowl. When it worked, it would get quieter when snow was on vehicle.
Old 01-17-18, 01:00 PM
Clutchless
Clutchless's Avatar
As a test, find the one in your vehicle and disconnect it. If there are no longer chime sounds, then you found the part. If not, it may be time to call a dealer parts department.
I would first see if it is in the engine compartment before removing the fender inner liner. That drawing location is not exact. I bet it is closer to the windshield/cowl area.
Old 01-27-18, 02:33 PM
Skier76
Skier76's Avatar
I'm still working on chasing this down. I'm thinking if it's not under the windshield cowl, it's by the front fender in the engine bay. I'll update once I have it pin pointed.
mopudding
01-15-18 01:59 PM
AlrightyJ
RX - 3rd Gen (2010-2015)
05-04-15 02:06 PM
IronCobra
ES - 5th Gen (2007-2012)
02-19-10 09:31 AM
truongsta8
05-06-05 10:44 AM
PhatLexus2001
IS - 1st Gen (2001-2005)
09-17-01 08:53 AM
Quick Reply: 2013 RX350 Alarm Chime/Beep Volume
