Oil cooler line advice
Hey all,
A couple weeks ago I purchased my first Lexus, a 2011 RX350 with 80k miles. I'm a DIY type of guy and have plenty experience wrenching so I did my own pre purchase inspection of the vehicle.
During my research before buying the car I seen some posts regarding the rubber engine oil cooler lines being replaced with an all metal version. My Lexus has the rubber lines which are not seeping or leaking.
I see this as an important update to complete and have the tools and skill to do it myself.
My question is this, I seen some posts saying they've been reimbursed for the repair, or had the dealer fix the issue at no cost, however mine is not leaking. Does someone have a copy of the tsb or recall notice I can show the dealer to get this taken care of?
I'm not above covering this line with old oil and letting it soak in before taking it in to have it replaced, as I'd rather not have an emergency situation when this line bursts.
Should I eat the cost and proactively replace this myself or let Lexus take care of it like they should be doing anyway?
Thanks guys!
Thanks guys!
There are recalls and there are TSBs and warranties. Also the recalls and TSBs are based on country of sale and apply to certain date of manufacture.
Check you vin against the TSBs.
Typically Lexus covers TSB during warranty period.
Salim
Salim
Call the dealer and talk to a service advisor. Say they're leaking and ask if it's covered, they should be able to tell you based on your VIN number. If it is "leaking" they will replace it with metal lines. I just got mine done, 2010 with 90k miles. They may not tell you this up front but they will charge a diagnostic fee if they inspect it and determine they're not leaking, in my case the potential fee was $172.50 (but mine ended up warrantied). You will not get charged a fee if they decide to replace it under warranty, and there's really no reason for a tech to spend the time to determine they're still good if there's old oil on it.
Our 2010 rx350 bought and mostly lives in southern Nevada. I've heard some people here in the states who live in the rust belt get their hoses changed out under the extended warranty. Even though I travel frequently to northern Nevada and Utah during winter, I could not convince the dealer to change my hoses. I've even had a talk with Lexus customer svc from California and they won't budge. It apparently has to be a significant leak before they'll do anything. I've taken this Rx to dealer for all maintenance, even the simple stuff like oil changes. Thought that might earn me some loyalty over the years but no dice. That's the last the stealership sees from me. Will change out the hoses myself later this year when it's time to do 110k mile oil change. In Canada, its a full blown recall, but in the US, an extended warranty only, and it has to look bad before they do anything. Good luck.
Hey all,
Thanks guys!
Thanks guys!
L-SB-0154-11 I have done this repair on my 2nd gen RX350, search our forums and around in general and you will see what it requires (tools, procedure, etc.) Takes about an hour to do, pretty tight, but not that hard IMO. Great piece of mind when done though. I ordered my part from Elmore TRD parts in California for like 57$. Includes both gaskets that had to buy separately before. Part number is in the TSIB that I will attach a PDF for in this msg. I did get refunded by Lexus after completion. Just email Corporate. On my model they call this replacement 9LC. Lexus will ask for a digital copy of your receipt of the part, a picture or two, and your VIN IIRC. You are correct in that they will only replace if it is leaking. Just replace it yourself, get reimbursed and drive feeling better.
I replaced mine with the OEM parts purchased via eBay for about $74. I learned about the tricks to removing it from the Highlander thread linked here.
http://www.toyotanation.com/forum/12...ooler-tsb.html
The thing is there is not much room to remove some of the nuts so it is easier to remove those studs instead. The details including the proper female torx bit to use to remove them is descibed in the link. The main difference with the Highlander is we do not have to remove a bunch of under body cladding. It is a tight fit and requires a bit of wiggling to get the hoses in and out.
Thanks for the reimbursement tip, I am going to try and find the receipt and contact Lexus corporate.
Yeah, e8 external torx, 10mm, and 12mm deep socket. I watched the Highlander DIY too and that guy takes off exhaust manifold and all kinds of things I didn't need to. For anyone looking for a good DIY video on this, there's one in the 2ND gen DIY sticky around the last page. It was how I did mine and explains removing the studs as Clutchless mentioned.
Last edited by BlackLexRX; 05-29-17 at 05:41 PM. Reason: Mispelled Clutchless, stupid phone spelled for me
Thanks guys. This is just the type of replies I was hoping for. I think I'm just going to tackle this job myself during my next oil change. Doesn't look like too bad of a job at all. Add that I'll also avoid a trip to the dealer and the risk of being denied replacement / charged for the inspection fee's.
Let me know how the reimbursement process works for you. I'll definitely be submitting that.
PDF clearly states that the vehicle must be under-warranty [date in service and/or milage which ever expires first wins]. If you have extended warranty then when ever the extended warranty expires.
Salim
Salim
Ive attached a pic of my reimbursement check.
Rather than play games with the dealer, and even though Lexus should RECALL all vehicles with these oil cooler lines, I'm going fix this myself and submit for reimbursement for the parts. If it's denied, so be it. $80 for peace of mind is worth it.
"Lexus should RECALL all vehicles with these oil cooler lines, I'm going fix this myself and submit for reimbursement for the parts. If it's denied, so be it. $80 for peace of mind is worth it."
Exactly. You should have no problem getting reimbursed, just have the info they ask for (receipt, etc.). They don't want to fix any that don't have to (aren't leaking), but they have no problem reimbursing those who do it themselves. My wife drives ours mostly too and having read peoples description of failures, it just goes. Oil light on dash flickers just briefly and before you know it, all the oil is gone...and engine fried. I bought mine from and recommend TRD Elmore Toyota parts. They have it for 57$, with both gaskets, OE, and fast shipping.
BlackLexRX,
I did not remove the manifold or all the other parts that Highlander guy removed. I thought he was nuts to do all that. I just used a universal joint extension with a wobble extension bar, plus the torx bit and deep sockets etc. I only moved the one wire in front of the hose.
