P0051- oxygen sensor bank 2 sensor 1
P0051- oxygen sensor bank 2 sensor 1 for RX 350Dear ALL, i have problem with oxygen sensor bank 2 sensor 1 for lexus RX 350 model 2009. Can i anyone help me to find the location for Bank 2 sensor 1 with picture if possible and also the spare part#. for the same. Appreciate your kind assistance. |
P0051- oxygen sensor bank 2 sensor 1 for RX 350 SOLVED
Originally Posted by rahiman9
(Post 9705654)
P0051- oxygen sensor bank 2 sensor 1 for RX 350Dear ALL, i have problem with oxygen sensor bank 2 sensor 1 for lexus RX 350 model 2009. Can i anyone help me to find the location for Bank 2 sensor 1 with picture if possible and also the spare part#. for the same. Appreciate your kind assistance. Thank you. |
Thanks for letting us know and sharing the solution.
Does anyone know the part number for Denso o2 sensor that is in bank 2 sensor 2.
Downstream front or after cat. I can't figure it out. Car was built in North America, Canada and has Ca emissions. I thought I narrowed it down to 234-4416 or DEN 234-4400. Napa says first looks like 234-4400 is generic Rx 350 and 450. Now the guy at parts not says 234-4509? It's a 2011 Rx 350, again made in Canada with California emmisions. The old cord is 10in which tells me 234-4416 is closest but can I go off the length of the wire? All the info on the web gives me a different answer. Does anyone know what the Denso Part number would be for this car Bank 2 Sensor 2 code P00057? Thank you- |
Try searching, I found this is a couple of seconds https://www.clublexus.com/forums/rx-...numbering.html
Plus a how to do it tutorial https://www.clublexus.com/how-tos/a/...-sensor-366256 |
I saw this link it didn't help. Right/Front or Left/Rear banks on picture don't fit with piston position.
Also the 234-4400 says Japan cars not North America. 234-4016 says downstream front for North America. Also the cord is 22 in. Dealer part is 10 in cord. Napa swears its 234-4016. Carquest says 234-4400 and Toyota has a completely different number. So yes I saw the link. Wanted to make sure before dropping the cash. At this point I might buy at dealer. Thanks anyway and I'll let everybody know if I find an answer to: Bank 2, Sensor 2 North America/Canada o2 sensor Denso part number for 2011 Rx 350. |
What part number does the dealer provide? Have you called the parts department? They usually will provide such information.
What does Rock Auto list? |
Dealer part 894650E040 Lexus
Rock auto by description downstream right DEN 234-4400 Japan or Canada or By cross number 234-4416 same as NAPA. Toyota tells me 234-4400? |
Have you inspected your 02 sensor and measured the wire to determine which cord length you need? That is what I would do to resolve this problem of conflicting advice.
Agreed. Would be denso 4416 10 inch cord. Installed today no codes yet!
