Navigation Upgrade
Navigation Upgrade
How does one update the map software on the navigation system on this (and I guess other Lexus) models? I have a Garmin portable unit that uses "City Navigator" and after a year or two, one can purchase an update to these maps showing all the street changes/points of interest, etc. How is this accomplished on the Lexus nav. systems?
Thanks
Thanks
the US RXs use HD navigation so i am guessing it can only be upgraded by the dealer.
over here our RXs still use DVD based navigation so its a matter of switching the DVDs, the DVD drive is hidden in the storage area under the center console but you have to remove the plastic trim/cover to get to it.
the older models ran based on a nav disc, so you would just swap the discs and you would have the better version. However, I think now, there is still a nav disc and you put it in the CD drive and it will "install"
With the previous gen nav that's in the LX/LS, it's updated by a USB drive. Probably the same with the RX.
Funny how many questions this topic gets... in the end who cares what the update process is? Either you pay to get it or you don't.
With my Infiniti EX35, also a HD based system, it was a flash card.
I just bought a 2910 RX 350 on Saturday, and it's hard drive based, and has the latest map version. There is a setup screen to update the map, and some warning about charges associated with it. I got the impression that the NAV could be upgraded over the air, the same way a Lexus Enform operator can send an eDestination to the NAV.
Knowing I already had the latest version, I didn't hit the upgrade button to see what would happen.
Seabone726 (04-07-20)
NP. I don't think anyone would put a nav in a car without some kind of update process. They've been out for quite some time (more than a decade), so not having a way to update would be outside the norm... the means of updating have changed in recent years as the tech has.
NAV upgrade
So this time of year I start getting mailers for discounted navigation software upgrade/update.
My 2010 model's navigation sucks big time, but general sense of direction and a look at the map has saved me from circling around my destination point.
I wanted to get the update, but the initial cost of $140 for the USB and then the added cost of $320 from $tealer to perform the update has kept me away.
Is there a cheaper option available to update?
TIA
TIA
No, I don't play soccer!
yeehawbob, I don't know where you got $140 from. My dealer quoted me around $95 for the USB update on my '10 a few weeks ago. Even Sewell has it listed for $93.94 with the discount. Here is the link. As far as installation, prices may vary. I'd suggest you call around to a few dealers.
tomgarv (10-11-21)
I talked to my $tealer and the nav software is $99, but installation is another $99.99, so I wouldn't call the update only $99. I called a non-dealer here in Dallas, and they tell me the dealer has to install it (at least for my 2011 RX 350).
I've found the part (PT219-HDDG6-14) for just under $85 online, but it still requires dealer installation. Still looking for alternatives.
In the end the Nav update will cost me about $200 at least.
nsnqst (10-14-20)
Navigation Upgrade
I have a 2011 RX350 that I bought new. Want to update the navigation system. Dealer is telling me it is a complicated process and they need to do it. I understand it is a USB stick so how tough can it be? Anyone with experience doing it?
Thanks
Thanks
There are a number of other threads and discussions about this.
The net is, IMO it's not complicated, but a 3rd Gen RX REQUIRES you both purchase the USB stick, then have Lexus Service connect to their proprietary system to unlock the copy protection of the USB stick so the data on it becomes usable. There is no way around that. My personal opinion is, the process was likely put in place given unscrupulous people that may have copied former non-copy protected CD/DVD/USB data solutions...
Hopefully 4th Gen RX will go back to allowing us to do the update ourselves as some other newer Gen Lexus Vehicles are allowing with updates coming on newer media types, but details like that remain to be seen after the new RX becomes available. There is also more info on the Lexus Navigation Site if you're interested.
For now, you're stuck needing to have some Lexus Service Dept enable a USB Stick that you can buy from any authorized Lexus supplier. Good luck.
