Tailgate adjustment?
Old 12-28-11, 11:52 AM
onerarevip
onerarevip's Avatar
Default Tailgate/Rear Door Height Adjustment?
Hello Everyone,
Is there a way to re-program the tailgate/rear door height? Or even manually adjust? Just purchased a 2012 RX 350, and my garage is about 4 inches too short. Now I realize I can disable the electronic lift, but it's a shame not to be able to use this feature. I'm sure others have had this problem, but I've googled with no success.
Thanks.
Old 12-28-11, 11:59 AM
jblazing
jblazing's Avatar
Not that I have heard of, but perhaps you can put some padding on your garage roof, so that your tailgate doesn't ever get banged up, even by accident?
Old 12-28-11, 12:26 PM
onerarevip
onerarevip's Avatar
Yeah, I was thinking of the padding idea.
Old 12-28-11, 01:35 PM
fr0mastaj
fr0mastaj's Avatar
When I purchased the car, i asked this question at the dealer and the answer was no.
I also have the same height issue with my garage. However, i am able to fully open the tailgate if i close the garage door first (just misses the track by about 1/2"!) If i have the garage door open, it will hit it. Not sure if that helps you at all...
Old 12-28-11, 02:46 PM
UCSB
UCSB's Avatar
I find it is safer for the vehicle to just open the door manually in the garage. I have a towel that I can put between the door and the garage door, if I need to leave it open for an extended period of time. I can use the automatic opener when I back into my garage.
Old 12-28-11, 05:51 PM
MEP7557
MEP7557's Avatar
No adjustment on the opening. It is what it is. I don't have a problem with the garage door closed. I was impressed that I could open the hatch with the garage door closed, the angle of the door and the way it swings requires less rearward room than most SUV's. Not so with my previous vehicle.
Old 12-28-11, 07:19 PM
LexRexBlue
LexRexBlue's Avatar
Couldn't adjust on the second generation RX. I was able to raise the height of the garage door. However, I have to open the hatch with the door closed. If you goof you do get a scratch on the hatch!
Old 12-29-11, 06:12 AM
MX5NES350
MX5NES350's Avatar
Walk around a lot and look at the pre-owned ones and you'll find many an example of the low garage ceiling syndrome.
Old 12-29-11, 07:54 AM
BurgBoxstr
BurgBoxstr's Avatar
You could just back in, no?
Old 12-29-11, 08:21 PM
Sfcyclist
Sfcyclist's Avatar
Doesn't the tailgate just use power to close and pressurized struts to open?
Old 12-30-11, 10:42 AM
sleepysurf
sleepysurf's Avatar
Even for those of you with 1/2+" clearance for the hatch when the garage door is open, WATCH OUT!! I had adequate clearance, but a couple weeks ago opened my garage door while simultaneously opening the rear hatch. I heard a horrible crunching sound, and found the hatch had wedged into one of the lateral garage door supports as it passed by. Scraped off a bunch of paint on the bottom edge of the hatch, but, fortunately, the hatch "gave" a bit, so no permanent dents, and the hatch mechanism appears intact. Doh!
Old 12-30-11, 01:14 PM
jblazing
jblazing's Avatar
Could you put a door guard on the bottom of the hatch to prevent this? May be more practical than padding.
Old 12-31-11, 05:35 AM
DunWkg
DunWkg's Avatar
The rear tailgate both powers open and powers closed. It has emergency reversing if powering open and also if powering closed and it hits an obstruction in either direction.
The pressurized struts act to counterbalance the weight of the gate making it easier for power operation and also manual operation.
Old 12-31-11, 03:20 PM
Sfcyclist
Sfcyclist's Avatar
I missed the part about opening with the button vs releasing it at the hatch. I have yet to use the button to open it.
Old 08-04-13, 10:43 AM
Sal Collaziano
Sal Collaziano's Avatar
I was just searching this for my 2013 RX350 and found this thread. I'm surprised to see Cadillac thought of something Lexus did not.
The SRX Crossover power liftgate with memory height allows you to open the rear liftgate to any pre-programmed height, and close it, at the touch of a button.
My RX has a few scratches as the hatch hits the garage door when opened all the way.
Quick Reply: Tailgate adjustment?
