I hope you guys get this figured out, because I wanna know why it is my windshield is covered with bugs and I invariably hit the wiper lever by accident and make a smeary mess.
The only exception is a light mist. A quick swipe usually gets it going for me.
But if you have to manually activate the wiper from time to time, then its not really a convience feature, you might as well just have a manual intermittent mode where you set it once and forget it.
I remember in my 05 GX, the rain sensing wiper was so bad that some owners had the dealer deactivate the rain sensor. The sensitivity adjustment then turn into a time interval intermittent adjustment. I am not sure if that is possible in the RX.
I have both. The top position is off. The 2nd is rain sensing. The third is intermittent, and the next two are low and high speed.
They work well and I'm glad I have them.
Jim, you've always had a special car! Most of us lost the intermittent setting when we got rain sensing.
I glanced at the on-line manual this morning and learned rain sensing turns off when the temperature is too hot or too cold. Although being too hot currently is not a problem
Really?? Mine were working yesterday in the mid 20s with a light mist. There wasn't enough moisture on the windshield to clean it so I had to turn it on and off during the drive home. Using the washer was out of the question. The headlight washers were encased in ice. I always make sure I turn off the rain sensing wipers when I leave the RX in this weather. I don't need to find out how much the motor costs the hard way
I manually activate the wipers once before I start to drive during a light mist. That's enough to make the rain sensing wipers work after that.
Mine was one of the 1st production models built during May 2009 and I got it the day it arrived at the dealership in late June.
I don't have some of the things produced today like the home link, but I do have many features I use and love you can't get anymore like the drop down sun glass holder and auto hi-beam. It's not perfect but sometimes I wasn't either . Anyway a few months later they started changing equipment around. I like mine. And it still say's 'Lexus' on the tail gate too .
Nobody has yet to produce the vehicle that will satisfy everyone!!
We know you are not perfect Jim, but we would like to keep you around anyhow!!
Here's the paragraph from the on-line manual. 20 degrees isn't cold enough to stop them from working. Believe me if my windshield is 194 degrees, I AIN'T going to be driving. Even with eco mode off, the AC is gonna have trouble!!
In extremely hot or cold weather(vehicles with rain-sensing windshield wipers)
The rain-sensing wiper operation will turn off if the windshield gets extremely hot (at more than 194°F [90°C]) or cold (at less than 5.0°F [-15°C]). If the windshield wipers cease operation while in AUTO mode, change to a mode other than AUTO.
By putting the auto setting to what looks like an "o" or "O" on the stalk, this will turn off the rain-sensing mode and then allows you to use the intermittent function.
Of course, this is what the setting looks like on the 350. I'm not sure if the 450h is different.
Thanks for all the responses. I checked on page 196 of my manual and it clearly states that the "o" position is off not intermittent. I guess I don't have the old school intermittent feature. It's too bad, it seems some like the new rain sensing feature and some don't; i fall into the latter. I guess i'll just use the manual up swipe (how annoying over a 30 mile commute). i almost never use a wiper any more often than 5 seconds when driving in the city and 2 second when driving on the freeway. Regardless of sensitivity setting for me, it's wiping too fast for my taste.
I'm really missing not having the sunglass holder up on top. I haven't found a safe and easy-to-access spot to put the sunglasses on the 2010, and I don't care for those flimsy gizmos that you clip on to the visor.
So auto-high beams are not available on the 2011 RX's that have the HID's?? I didn't know that. I kind of like that feature too.
