RX350 Transmission Oil Change (merged threads)
#256
Great info Tempestv8. Your linked video makes the drain and fill look so simple that it is very tempting to DIY. I'll take a looksie at my RX once I have it back from the dealer, to assess a go at it.
#258
Actually not so! If you read what they consider severe use it is what we encounter everyday in our life, like, short trips, dusty environment, too cold or too hot temperature and more ( I don't have in front of me all of what they consider severe) towing a trailer above a certain weight is certainly one of them, once you read this you realize that normal use is something so fleeting that it can't be captured by us mere mortals.
#261
You know, the same engineers that make these cars what they are today .. ... let that sink in. ..
#262
Guys .. give it a rest.
Fair warning.
Salim
Fair warning.
Salim
#263
On my other vehicle which is a conventional 6 speed auto (Toyota AB60F) I decided to do a fluid check, as the fluid was last changed 100,000 kms ago. This transmission uses the same Toyota WS fluid and even the service maintenance booklet has the same change interval as the RX350/RX450h - I was a little overdue by 20,000 kms. I proceeded to drop the fluid today to have a look, expecting it to be in poor condition, as my vehicle is operated in "severe" conditions; I tow a caravan away on summer holidays, and it's been 3 summers since the last fluid change. Much to my surprise, the old fluid was in pretty good condition as can be seen from this video clip.
Perhaps there is some credence to the "lifetime" properties of the Toyota WS fluid. Still, it was a huge contrast to the 45,000 km old fluid that came out of the RX450h. Perhaps instead of replacing fluid, it may be sufficient just to check the fluid by undoing the drain bolt and letting a small amount of fluid seep out, and just checking it before going to all the trouble of draining and filling the transmission.
#265
How about a crowd sourced "science" experiment by various people getting fluids analyzed when they change it and posting results here? There are many variables that will be different which is why "science" is in quotes but i think that's the closest that we can bring some science to this discussion. Too bad that I didn't get a sample from my last tranny change so it will be at least another three years for the sample from my 2011 driven in -30C to +30C, city driving commute (average of 30 kph), long drives on highways. Anyone?
#266
I have a neighbor who owns a transmission shop here in northern Wisconsin ( he's owned and operated the shop for 30 plus years) I talked to him about this issue, and he told me that these transmissions are really over built and will go 300K without a fluid change. He did qualify that by saying if you pull heavy loads a lot or off road it where you would get into deeper water , like crossing a stream, then yes change it. He also said do not have it changed using the machine exchange type methods. If you do change it he recommends using only the WS fluid and dropping the pan. I asked how many he sees in for repairs and he told me maybe 1 or 2 in the last few years, and those had signs of moisture and very hard use and higher miles. So when the manual says don't change and the transmission fluid and the shop says don't change unless you ford streams or pull heavy loads I'll go with that and take my chances, mine only sees roads and normal driving conditions. I have a 2005 GX with 145K and a 2012 RX with 86K and both have had zero problems and shift smoothly.
#267
#268
#269
I just realised that the video I shared is for the RX450H - which I've previously shared in the Hybrid section. So for non hybrid transmissions, e.g. RX350, the drain and fill plugs are in very different locations, and the process is a bit different because the fluid level needs to be checked at a certain temperature.
https://www.youtube.com/watch?v=eZRNPl-D1bY
I think that I'll just take it in the chin like drunk guy vs Mayweather on his way to his main event, and pay the $180 to the dealer eventually.
#270
Just do a cold drain and fill and ignore the insane Toyota temperature dependent procedure. Make sure your vehicle has sat overnight and the new fluid stored in the same location so both are at the same temperature. Drain the fluid, you do not really have to raise it up. Remove the fill bolt first, which is easily accessed via the driver side front wheel well. On the drain plug, be sure to remove the overflow plug after you take out the cover plug. Carefully measure how much fluid drained out (about 2 quarts) and replace exactly that amount plus about 4 ounces extra for spillage. I have done this 4 times on the RX and several more times on my old MINI Cooper that had an Aisin transmission with the same procedure. It has always worked and my vehicle shifts great. It is as easy as changing your oil.
mjdgarage (07-21-23)
