Diff breather type ?
Just double checking , 2011 rx350 ( North America ) The breather valve on top of the rear differential, is that the pressed type or threaded . Looks like it's pressed to me. Anyway to change it , without dropping the Diff ? Thanks
It's leaking little oil on both side of the ax seals , when I was changing the fluid and took the drain plug , I heard air pressure release . So...I am guessing the valve is the problem , not releasing pressure and pushing the oil out...common problem.
If no one answers, you can try to visit online parts retailer and drill down the differential and they will show you the picture of all attachments ... you may even discover a need of a seal.
Salim
*Bell Lexus of scottsdale Az or Lexus of South Atlanta etc [No affiliation other than paying customer with no issues]
Salim
I can't even seem to find the part number for it....it shows the threaded plug , but all the 2010 and up diffs I have seen , they have the pressed plug....
@zeusapolo
90930-03075 is the number
It's not a threaded one like on the older RXs, it's a push-in style one. I haven't done it on my 2014 RX, but it was easy to do on my 2008. Does not look fun to access on these newer ones
@zeusapolo
aeroelasti
Sep 29, 2014 04:06 AM
