Will software update fix Bluetooth problem on 2015 RX?
Old Jun 14, 2024 | 05:02 AM
Kingnole's Avatar
Kingnole
2nd gear
Default Will software update fix Bluetooth problem on 2015 RX?
Hello 3rd gen owners. I have a 2015 RX 350 that will not allow me to talk hands free over Bluetooth. I've posted on here before to no avail. In sum, I can play music and video from my iPhone 13 without issue, and can make and receive calls. I can hear callers clearly, BUT they cannot hear me. I've replaced the Bluetooth microphone, and have tweaked the volume on the system without success.
Lexus suggested a software update to the infotainment system, at a cost of approximately $125.
Has anyone had success fixing Bluetooth problems with a factory software update?
Old Jun 14, 2024 | 06:40 AM
Clutchless's Avatar
Clutchless
This has been asked before, although I am unsure if there was a solution. Do you have the latest software update on your phone? Have you tried disconnecting the car battery for 30 minutes?
Try this:
Check the Bluetooth in the iPhone. Under Settings open up the Bluetooth screen.
Find the banner that should say Lexus RX or perhaps Car Multimedia. If your phone
shows a banner that reads "Car Accessory System" it indicates a corrupt pairing.
Works but poorly. Delete the car from the phone and the phone from the car and repair.
Much more basic phone protocol - turn the phone fully off, dead, dark, cold at least once a week.
Also: Remove the Bluetooth pairing for your phone as an audio player, just Bluetooth your phone as a phone. It's possible that your phone is not liking the dual connection.
See this link which then links you to more similar threads that may help:
https://www.clublexus.com/forums/rx-...t-hear-me.html
Old Jun 14, 2024 | 02:37 PM
salimshah's Avatar
salimshah
25 Year Member
One thing to keep in mind that although the device is the phone, but there are two different connections [phone & audio-video].
You may like to clear/delete the existing connections and start again. You may even have to power down and restart the phone. My iPhone case broke and I even had to clear and re-install from cloud.
Things have been changing to rapidly with mobile devices, that tech support will insist that the firmware be the latest [they follow a cheat sheet and work of a flow].
Salim
Old Jun 15, 2024 | 04:48 AM
Finalist0946's Avatar
Finalist0946
Salim
Speaking of that, has anyone figured out a hack to the RX software so we can update without paying that ridiculous fee?
Peetie
RX - 3rd Gen (2010-2015)
Oct 2, 2025 11:52 AM
Lexypoo25
RX - 4th Gen (2016-2022)
28
Feb 20, 2022 02:10 AM
Emaniat
Oct 16, 2019 10:54 AM
atomarchio
Dec 16, 2014 07:26 AM
