Changed Driver CV axle, where to put fluid
Old May 22, 2021 | 07:02 PM
cberry2002's Avatar
cberry2002
Default Changed Driver CV axle, where to put fluid
Hello guys, new to this forum. I have FWD only 2007 RX350 and I changed the driver side CV axle yesterday. When I pulled the axle out, a lot of dark fluid came out. I have replaced the axle, but cannot find where to replace this fluid. I checkd the ATF on the dipstick and it is perfect. I looked, but could not find anything that I felt was fill plug. Any help with information about replacing this fluid would be appreciated. THank you.
Old Jul 7, 2021 | 06:16 AM
snydertalo's Avatar
snydertalo
Did you ever find out what fluid this was?
Old Jul 7, 2021 | 07:37 AM
Mesquite77's Avatar
Mesquite77
So, on FWD, when you pull an axle, any leakage will be ATF, since it is a transaxle, so no separate diff. On mine, and many others, the ATF seems filled high at factory, but is temperature sensitive. The way to add ATF, is through the tranny dipstick tube, use a small funnel. A small amount of fluid can look like a big leak, so add a bit at a time....
E46CT
CT 200h Model (2011-2017)
13
Apr 12, 2019 10:58 PM
javohio
Jul 10, 2015 09:15 PM
