vibration at 65mph or above
Old Jan 29, 2021 | 01:38 PM
matts6887's Avatar
matts6887
could one or both lower control arms wearing out be to blame for this?
Old Jan 29, 2021 | 05:28 PM
iMSQ's Avatar
iMSQ
https://www.clublexus.com/forums/rx-...l#post10979235
Old Feb 2, 2021 | 07:00 AM
matts6887's Avatar
matts6887
well actually; i think i found out my issue. yesterday i went to have my tires looked and and possibly rebalanced only to find out the outter edge of one of my right front tire was totally dug in and so i definitely think if i replace the tire which i intend on getting done that it hopefully will solve the vibration issue.
Old Feb 3, 2021 | 09:34 AM
Margate330's Avatar
Margate330
Do you have pics?
A bad or defective tire can be annoying when trying to figure out a vibration especially when they are newer since most people assume it can't be the tire.
Old Feb 3, 2021 | 02:03 PM
matts6887's Avatar
matts6887
Do you have pics?
sorry no pics of the old one; but i can safely tell ya the outer edge was totally and completely worn all the way around and u could see that it probably was most likely the cause of my vibration in the steering wheel at 65 and above. Now, tomorrow im going to get a alignment done cause im just about positive I need to get that done as when i let go of the steering wheel very briefly; it starts going to the right little by little.
Old Feb 3, 2021 | 03:32 PM
iMSQ's Avatar
iMSQ
... tomorrow im going to get a alignment done cause im just about positive I need to get that done as when i let go of the steering wheel very briefly; it starts going to the right little by little.
Ask them to check your suspension first, otherwise, it will be a waste of money (alignment + tires).
Old Feb 3, 2021 | 06:21 PM
Margate330's Avatar
Margate330
For sure...
Old Feb 4, 2021 | 07:02 AM
matts6887's Avatar
matts6887
yes i will. I thought i had them check it before but i will have them double check it to make sure nothing other than the partially torn bushing is out of the norm.
Old Feb 4, 2021 | 03:02 PM
matts6887's Avatar
matts6887
well as it turns out; the "toe" on my front end was slightly off(but it was so little and took so little effort to fix he didnt even charge for it); and for another it turns out i was still having a pulsing of the brakes when slowing down and coming to a stop; so the excellent manager of local indy shop down the street test drove it; now he said he didnt feel anything; but; his tech that was working on my rx did!; so the manager is warrantying the front and is putting all new pads and rotors on the front; but that wont happen til saturday or next monday as he had to order the new stuff i needed. now hopefully after all this is taken care of these vibration issues will be gone(hopefully)
jcbikes
Jun 12, 2021 08:12 AM
Fillay
RC - 1st Gen (2015-present)
Oct 9, 2020 04:55 PM
matts6887
Oct 8, 2020 08:30 AM
hmkim
May 25, 2010 12:50 PM
hmkim
May 19, 2010 09:56 PM
