Does your rx350 use oil?
Old Jul 16, 2020 | 08:05 PM
iMSQ's Avatar
iMSQ
Originally Posted by fabchef
I usually do my oil changes at around 5000km. In that interval, i'd say i'll add between 1-1.5L oh oil. Is this normal?
fab
No, it's not normal
Originally Posted by Felix
You'll possibly find that manufactures mention its acceptable for engine to use a qtr of oil 800-2000 miles. Really depending on the engine & manufacturer....
Just because they don't receive claims from customers. Need to refile oil between services? You have to repair your engine (because of age or because of bad engineering)
update...
dyno oil.
What is this? Engine repair is not cheap. So, use oil from well-known brands only.
Old Jul 17, 2020 | 03:57 AM
fabchef's Avatar
fabchef
I recently switched to Mobil 1 super 1000 non-synthetic oil. I have to say, off the bat, the car ran much smoother and consumption has reduced quite a bit. It seems to be a hard oil to find.
Old Jul 17, 2020 | 08:37 AM
matts6887's Avatar
matts6887
how many miles on your rx? mine has a bit over 146,000 so far and so far mine hasnt been "using/burning" oil as far as i know; but this will remind me to start checking it every day
Old Jul 17, 2020 | 09:49 AM
fabchef's Avatar
fabchef
Close to 200 000km
Old Apr 15, 2025 | 02:17 PM
Felix's Avatar
Felix
Also, been reading on this oil, seems to mostly be a for-Canada product, but might be getting phased out? 😟
The engines aren't asembled there, so that wouldn't matter........
Old Apr 15, 2025 | 03:16 PM
Leeper's Avatar
Leeper
Felix... you going around reviving 5 year old threads again?
Old Apr 15, 2025 | 04:43 PM
Felix's Avatar
Felix
Yeah as nothing happening here, so going thru old threads here....
Old Apr 15, 2025 | 05:30 PM
Leeper's Avatar
Leeper
Start an oil and tire thread, or maybe find out which color is best
Old Apr 15, 2025 | 08:51 PM
Margate330's Avatar
Margate330
I'm on it!
Just for you friend. 🤣 🤣 😄
We like talking about oil. 💯
Old Apr 15, 2025 | 08:52 PM
Margate330's Avatar
Margate330
I pick thru old threads sometimes too.
Old Apr 15, 2025 | 08:54 PM
Leeper's Avatar
Leeper
What's better... Amsoil, Royal Purple, or Mobil 1 and why?
And for the AWD trans Max life, OEM, or other?
Lastly how often should I change my oil? Every 3k, 5k, or 7500 miles?
Old Apr 16, 2025 | 04:59 PM
Felix's Avatar
Felix
Default For a RX...
For a DD rx, I'd use M1 0/40 about every 3K w/ a Wix,K&N or M1 filter, Maxlife trans fluid/Wix about every 30K as well as 2 qtrs of RR 75/90, for the diff & transfer case. For you or others, that'd depend on your driving & how far. Some ppl like to go farther on changing the oil/filter.
Old Apr 16, 2025 | 05:20 PM
fabchef's Avatar
fabchef
Well for me, i stick with 5w-30. Today i decided to switch over to High Milage oil. I went with the Canadian Tire brand (made by Shell). It's not a bad oil. I'm religious with my oil changes and usually change at 5-6000km max. I often go with wix or napa gold filter. Today i went with a fram ultra guard filter (i was stuck).
for tranny i used maxlife oil. For the transfer case and rear diff i go with 75/90 synthetic oil. These 3 i change at 60 000km.
Old Apr 16, 2025 | 06:20 PM
MattRX's Avatar
MattRX
I recently switched to M1 0W40 engine oil (Lotus Exige, Evora, Emira - 2GR spec) on my RX and it has been working very well for me. It didn't solve my cold start rattle, but it did reduce its length, and the "piston slap" noise that is common on 2GRs when cold is now basically absent. It seems to flow extremely well when the engine is cold. Not a hair over 8000 km / 5000 mile changes for me.
I run Toyota WS in the trans with a wix filter, and Redline 75W90 in the front transfer case and rear diff. I use Dexron VI synthetic transmission fluid in the PS system (From Canadian Tire), that's discontinued though now, so next flush it's getting Maxlife.
Old Apr 16, 2025 | 07:18 PM
fabchef's Avatar
fabchef
mattrx...i too use thr dexron for ps application. I usually find it at a local auto parts place or Napa has it too.
