Replaced brake switch now cruise flashes?
Old 12-04-18, 11:36 PM
zbutler
zbutler's Avatar
Exclamation Replaced brake switch now cruise flashes?
I have 2004 RX-330 that I did the replacement switch from Duralast@ Autozone>I had to trim the plug tail to make tight clearance!>The switch is fine...I think>But no matter how I adjust the switch>The cruise will no longer set regardless?>Any ideas as to my quandary??
Old 12-05-18, 05:14 PM
Audiqv8
Audiqv8's Avatar
Why was the brake light switch replaced? Trimming the plug tail indicate either a poorly constructed switch or the wrong switch. The cruise control uses the brake light circuit to determine when to disengage cruise control. Since you're doing the work yourself I would buy a genuine OEM TOYOTA BRAKE SWITCH. Is the brake light on when you depress the brake?
Old 12-07-18, 01:25 AM
zbutler
zbutler's Avatar
Yes the switch solved the 5 lights that stayed on in dash>>It works when depressed.I just don't know if I have new problem or the switch just will not let cruise work??>P.S> The other switch was definitely bad>>but cruise use to work before replacing switch.
timh1990
GS - 1st Gen (1993-1997)
08-02-15 11:28 AM
wayne86
10-24-08 12:52 PM
ftltarpon
RX - 1st Gen (1999-2003)
03-27-07 02:22 PM
SSmith
SC- 1st Gen (1992-2000)
07-05-02 01:25 PM
Quick Reply: Replaced brake switch now cruise flashes?
