I beleave my front wheel bering is going out
Starting to get some noise at about 60 mph just bought the car about a 1000 miles ago but it seems like it started about 500 miles ago.I dont want to bring it to a shop.i dont mind spending the extra money on parts if it will make it easier to do the install with out haveing to bring it to a place to have the bering pressed out and iback in .So is there a supply company that sells a kit for this .This whould be for the front on a awd .Make it as simple as possible. Thanks.
So do you KNOW it's bearing or you think it's bearing?
Did you test it?
As simple as possible is to replace the hub. Hubs are inexpensive. I am pretty sure, Highlander hub should also fit. Any time you say "Lexus" in the parts world, it somehow magically jacks price up higher.
If you intend to DIY it, bearing or hub, you will need proper axle shaft socket and impact wrench. You can rent "Front End Socket Kit". Unless you get lucky with cheat pipe, axle nut is a bear to undo without impact wrench. The rest is pretty easy.
Did you test it?
I did jack it up still was hard to tell.I have had them go out on other cars and sure I could be wrong I do have a devault heavy duty impact electric like 700 foot pounds .and up to 32 mm sockets. I did look up rock auto seals a one piece Moog for $230. Yes may be a little more but kinda nice I can take the old out and put the new in rather than trying to find someone to do it.plus I work like u days a week so I will have to do it at night .so now I just need to make sure what side it is .
Sorry I did not have them done car has 104,000 miles .I have had c.v a else go out on many front wheel drive cars so I know what that feels like and the click.Then Click some more and the boot gets rip dirt gets in and bam .Thank you for the info so far .
