Solution for cracked Key cases
Old Sep 25, 2018 | 01:25 PM
mandyfig's Avatar
mandyfig
Default Solution for cracked Key cases
I posted this on the SC Forum, I have converted both my keys with this new case, it works.
Old Sep 25, 2018 | 01:28 PM
mandyfig's Avatar
mandyfig
Warning though, my 2004 RX330’s key did not have the wing feature as shown. So I will have to modify my key (yes I have destroyed my key already) to fit this case and for it to work. For now I am using the case and my spare Transponder key. I have an idea and if it works, I will post it here.
Old Sep 26, 2018 | 06:38 AM
nwfsnake's Avatar
nwfsnake
I fixed both of our key cases that had broken with JB weld and my Dremel-like grinder/sanding tool. Been holding up for several months now.
Old Sep 27, 2018 | 04:22 AM
mandyfig's Avatar
mandyfig
The JB weld or something similar is what I am thinking of using to re-build my RX330 key so I can actually use this case (missing wing).
Old Sep 27, 2018 | 06:24 PM
ToledoRX's Avatar
ToledoRX
I got it for about $10 after my keyfob shell started cracking. I think it fits well though the plastic scratches easily.
I also had to pry out the metal key tip from the OEM keyfob shell using a pair of pliers so now the original keyfob is just a collection of plastic shards.
Old Sep 28, 2018 | 06:11 AM
Audiqv8's Avatar
Audiqv8
If my key broke, I would just get a new key cut and move the remote from the old key to the new. I have order keys from 1010keys before and was very satisfied with their service.
Old Sep 28, 2018 | 08:38 AM
mandyfig's Avatar
mandyfig
Wow, I did not realize that there are new options out there. Especially the 3 precut keys for the price. It is almost too good to be true.
Old Oct 4, 2018 | 02:29 AM
brainsurge's Avatar
brainsurge
Also it is possible to use the keydiy keys! However, you have to program them through the app, which i possible with a normal android phone! price is around 30$ + whatever the key cutting costs. you can buy them from aliexpress for example, and there are a lot of different designs available.
Old Jun 23, 2022 | 10:44 AM
workplay's Avatar
workplay
2nd gear
Default Dealer wanted $400 to replace my key fob! WTF!!
STAUBER is an AWESOME solution! My greedy local Lexus dealer charges $335 for parts and "additional programming charge" for one replacement key.
Love my Lexus, HATE LEXUS DEALERS!!!
Old Jun 23, 2022 | 04:31 PM
cdnewton's Avatar
cdnewton
After several broken keys over the years, awhile back I ordered the key mentioned by the OP.
Several years later, still going strong -- highly recommend the STAUBER solution.
Old Jun 23, 2022 | 07:44 PM
shahir18's Avatar
shahir18
https://yotamd.myshopify.com/
Old Jun 24, 2022 | 07:25 PM
Felix's Avatar
Felix
The oem fob is a real light duty piece, I replaced w/ them w/ a better designed fob off Amazon.
blanks81
GS F (2016-present)
59
Sep 25, 2024 12:23 AM
Nauticalx
RX - 3rd Gen (2010-2015)
25
Jun 8, 2021 08:25 AM
varuscelli
19
Sep 28, 2015 11:49 AM
gentouru
Sep 26, 2011 09:54 PM
