Passengers windows won't roll down from driver side master controls
Passengers windows won't roll down from driver side master controls.
If I go on singulars doors all windows roll down/up perfectly. From master control drivers prosition I can only roll down/up my window. I have already reset all windows... sun roof too. Tried to disconnect battery 10 minutes and then reset all windows another time. If i use the command key for roll down/up all windows together the car roll down/up only drivers window and sun roof. I have a 2004 lexus rx 300. :cry::cry::cry::cry: |
Check the fuses. Also is your window lock out button pressed in? It might be as simple as that.
Originally Posted by zorzside
(Post 9500615)
Originally Posted by Badhobz
(Post 9500678)
Now I check all fuses. thanks. |
All fuses are ok.
Update: The problem disappear when the right door is open.
So the problem due to the sensor of door closed. When the sensor is pressed the problem reappears. Any ideas? I've tried to exchange the sensor of front passenger door with the sensor of back doors. I think the problem is on cables or some connectors. |
SOLVED.
I have open the cover under the passenger dashboard on right side, disconnected and reconnected the plugs and now all works fine. https://cimg9.ibsrv.net/gimg/www.clu...f88419a665.jpg https://cimg1.ibsrv.net/gimg/www.clu...a3e2e872a4.jpg |
Nice troubleshooting!
windows
I have the same problem with a 2007 rx350. I tried everything you did but check the connections in passenger door. Is yours still working or was this a temporary fix?
I had also tried to have the passenger door open and tried to open windows from drivers door. Still does not work. Each individual door button works perfect. |
also there are no blinking lites on drivers door buttons
Originally Posted by Yamaha65
(Post 9509624)
I had also tried to have the passenger door open and tried to open windows from drivers door. Still does not work. Each individual door button works perfect. Try to open other doors. Have you tried to check the connections? In my case the issue appear only when the circuit is closed (sensor door). |
My driver side rear window isn't working from the driver master control and I was wondering what to do. Voila! That's why I love this place.
All fuses checked okay. The driver rear switch works. Will have to pull the passenger foot panel to check it out. Thx! |
Originally Posted by brianmch
(Post 9522570)
If the Rx ever lose power you will need to reprogram the switches. 1st you need to turn the ignition to on. 2nd go to each door and roll down the window AND continue to hold it down for 3sec. then roll it up AND hold it for 3sec. Repeat the step on all door EXCEPT driver door.
Ok. All is good. I have them all working.
Roll down each window and hold three seconds and roll up and hold three seconds WORKS
The below worked for me tonight on a used 2007 GX470 I bought and is worth a repeat!!!!
Originally Posted by Canhzx
(Post 9539640)
| All times are GMT -7. The time now is 11:54 AM. |
