RX400h Rattling when going up hill
Old 04-22-15, 10:44 PM
churchill
churchill's Avatar
Default RX400h Rattling when going up hill
Hello! I have a 2006 RX400h with about 110k miles on it. Recently, I noticed a rattling noise coming from what sounds like underneath the car when I'm going up hill (at or around 15-25 mph). Does anyone else have this issue and/or know what causing it? Thanks!
Old 04-23-15, 06:25 AM
thomas1
thomas1's Avatar
Lots of different places to look...Could be exhaust system, or Gas tank plastic cover...(I just found mine was cover hitting underbody/tank) I added foam to those points and noise gone.
Old 04-23-15, 10:33 AM
LexusLadi
LexusLadi's Avatar
Could be a lot of things, get underneath and try to poke around. If anything is loose or wiggles, that's probably your starting point. Good luck.
Old 04-23-15, 11:57 AM
smassey321
smassey321's Avatar
I sometimes get a rattle from my rear brake calipers. Next time you get the rattle, put the shifter in N and press the brakes. If the rattle goes away it is the rear calipers. Putting the shifter in N disables the regenerative brakes.
To fix the caliper rattle, remove the pins and put some brake grease on them.
Old 04-24-15, 09:04 AM
churchill
churchill's Avatar
Thanks for the ideas! I will take a look and see what I can find before going to the dealer for service.
Threxx
Suspension and Brakes
41
11-13-17 11:03 AM
lex460l
09-22-14 05:50 AM
Flapjack1
11-12-12 11:39 AM
RXGS
14
03-25-12 11:12 PM
silva1181
12-22-11 08:11 PM
Quick Reply: RX400h Rattling when going up hill
