Rear Liftgate opening at different speeds
When using the remote to open rear liftgate, the liftgate opens at a slower speed than using the interior switch. Anyone else noticed this difference?
Welcome to Club Lexus, javohio!
It opens at the same speed either way for me. I went to my car right now and pulled out my stopwatch and timed it. Just about 8 seconds from the beep to fully open. About 11 seconds from the beep to fully closed. Same times whether I used the interior switch, the remote, the switch on the jamb (to close), and the switch right above the license plate (to open; mine is set to power open when you use it. The factory default is to manually open when that switch is used). I have an 04 RX330 by the way. Maybe try timing it, and see what the times are? |
