Will Gen3 RX350 19" wheels fit the Gen2 RX350?
Hi guys,
Looking at a set of 19" from the Gen 3... 19x7.5 +35 114.3PCD. Currently i've got the 18" from the Gen 2.. which is 17x7 +35 114.3PCD. Do you reckon it'll clear.. i'm guessing it'll be okay, how about caliper clearance? Cheers Howie |
Yes they will clear, the 2RX has a pretty small 2 piston caliper design.
Thanks mike ur a champ.
Same bolt pattern and offset so it should fit. Depending on the tire size it'll look like a lifted truck if you're not lowered.
Currently the tires on the 18x7 are maxxis 235/55r18. I'm most likely going 255/50/r19 which is according to the tyre calculator less than 1% of rolling diameter of the stockies... Can anyone verify that this will work?
Originally Posted by koric
(Post 6459742)
Originally Posted by Howiefied
(Post 6459767)
Yep also lowering on TTE springs next week. 30mm drop.
Yep, 255/45 should be within spec.. i've seen a Kluger (Highlander) running them on 19's no problems.
P.s. Sewellparts having a close out sale on TTE Springs for the RX.. $95 bucks :) |
My answer is yes, they fit. I have a brand new set of 2011 RX350 19 x 7.5" takeoff wheels with Michelin tires (235/55/19) and I just tested fitted them to our 2008 RX400h. There is about a 2-3mm clearance of the front brake calipers but they do bolt on just fine.
I will have the TPMS sensors removed from the stock 18" x 7" hybrid wheels and put on the 19" wheels in a few weeks. Can't wait! |
Nice! Thanks for the info. Would you happen to have a pic of them on?
1 Attachment(s)
Here's a photo of my 2005 RX330 with the Gen3 RX350 19" wheels. Enjoy!
Meego mchengphoto.com |
Man that looks hot! Nice work. Got a side profile?
hows the ride? and is it more firm now coz i hate how my 17" feels
thanks |
Originally Posted by Benzat17
(Post 6474915)
thanks Meego |
(Post 6474908)
