RX330 need after-market wheel bearing
#31
I read the whole thread and noone asked, but I must. Why are you replacing wheel bearings? Did the dealer or mechanic diagnose and say they needed to be replaced, did you hear grinding noises, etc.? Just asking because I want to know if it's something I should be looking for.
#32
At any rate, I started taking the car around for 2nd 3rd and even 4th opinions. Learned from 2 muffler shops that there was nothing wrong with my resonator. Learned from 3 shops that my struts and shocks are fine. The conclusion from all was that I needed a right rear wheel bearing - one mechanic spun it for me so that I could hear the noise .. and he was also honest enough to tell me that I could wait another 10k miles to replace it!
I know this is more than you wanted to know but just thought I would mention because, not knowing how to repair my car, I have learned to get 2nd opinions on major work and would recommend the same to you.. e.g., if you are told you have to replace wheel bearings because of some noise.. get it checked.. and checked!
#33
Exactly as I have experienced it. First noticed I no longer had that quiet Lexus ride ... !
#34
Just ordered Timken rear wheel bearing hub assembly for $191 at Autozone. Seems like a fair price. Duralast $40-50 less but store did not recommend it 'if I planned to keep the car longer than a year!'
#35
Also, glad to hear you found a more reputable shop. Can just imagine the number of other customers your previous shop ripped off on bogus repairs.
#36
Exactly... I have told the people who followed me there; one was not surprised, another was shocked... but none have returned. If you don't know how to fix it yourself, you really need to be able to trust what you are being told.
#37
racing sound at low speeds?
Lately have been hearing a sort of racing sound.. e.g., high rpms at low speed or when idling; out of sync with acceleration. The car drives well, I don't hear any knocking or 'bad' transmission sounds. Could this be revs of the continuously variable transmission or a dirty idle air controller (IAC) valve?
#38
#39
dirty IAC valve?
Thanks, RX330inFL, missed that. Yes I do have the RX330... Do you think the 'racing' sound could be a dirty IAC?
Just had the wheel bearing replaced and it's possible that what I am now hearing is normal but since I had been hearing the road noise with the bad bearing for some months, I may have forgotten what 'normal' sounds like.....
#40
Is the A/C on? Wondering if you are hearing the compressor clutch on the A/C unit.
If you do not notice anything, next time you have it out for errands or such check when you get back to the house to see if you notice it then.
#41
on my current honda...you would hear alot of metal on metal "scraping" noises anytime the wheel was turned to the right. It wasn't too bad in the beginning but then it progressed and progressed. And it just had to go.
#42
More than likely the CV Joint and/or boot. Not terribly expensive considering.
#43
If the problem occurs when idling I would pop the hood and see if you can hear the problem while under there. Also, if the engine is what is racing, no matter the cause, you would see it on the RPM gauge.
I checked the RPM gauge and it doesn't show up on that. I did park my car with the engine running when I first heard this, got out of the car and could hear the sound as it sat idle. This only goes on for a second and then stops altogether when it is parked idling.
I have read elsewhere that this 2005 has a loud engine... ? Do you think this could be the IAC valve? Thanks.
1WILLY1
08-18-16 05:25 PM
