Please help: 4 indicators on dash come up @ same time
05 RX330 AWD, which we use only 2-3 times a week. All of a sudden, the dash lights up with low tire pressure, ABS, and 2 other lights. What could that be?
P.S. I had misspelled "Please" but found no way of correcting that after post is made. |
Originally Posted by Kostyan
(Post 5143653)
Originally Posted by Adamjeeps
(Post 5143692)
A common issue the the brake light switch behind the brake pedal. I don't know how much it costs to replace because the dealer replaced mine under warranty.
Same issue as mine....I have checked all TSB's and no specific mention of this issue.
(Post 5143701)
what lights were on, what symptoms did you have with your RX?
Originally Posted by mandyfig
(Post 5143740)
Mandyfig, have you looked at this sensor yet? |
I have no clue what to check. Let's wait for my Service advisor's reply. Mine will happen intermittently. I have seen it 4x for the last 1.5 weeks. Once it is on, it stays on. It does not come up when you 1st start your car.
I believe it does not affect your car, but it is certainly irritating, specially the blinking low pressure tire...:mad: |
I believe it does not affect your car, but it is certainly irritating, specially the blinking low pressure tire... |
AdAMJEEPS, how did the dealer know its the switch? Did ECU throw a code and which one?
The symptoms have dissapeared completely while the temps were a bit warmer here in Mid Atlantic (high 40's). Today, the temps fell back to the 30's, my wife drove the RX this morning and saw the lights come back on! I want to take the RX to Autozone to have the code pulled this weekend and go from there to confirm its the switch and nothing else. Mandyfig- did you get yours fixed? btw I saw someone's post on here they had to replace the 02 sensor for lights on the dash type of problem... |
As I posted in my thread, the OBDII did not show any recording. ZERO. And I knew for a fact that the lights went on twice prior to me testing it!
I need Lexus to tell me what's wrong. Quite annoying! |
(Post 5161967)
My tire pressure is checked every 2 weeks. Always at 34 psi. That rules it out for me. CEL light is not on, hence no report on the OBDII scanner. This is really annoying.
Will bring in next week to the dealer. |
(Post 5164442)
Oh shoot, I was not even thinking about the spare.
However, I have an 04. Therefore the spare tire's pressure is not monitored...! |
took the wifey's RX for a spin and encountered the lights: the ABS, emergency brake, VSC, and low tire pressure were on. The low tire pressure was blinking, others were steady on. Restarted her up and they went away. Went to Autozone and just like madyfig said, no codes.
Low tire pressure should not trigger other lights to come on. |
