A trip
Old Dec 25, 2009 | 07:40 AM
shikbas's Avatar
shikbas
Default A trip
Hi guys,i am ready for a long trip driving rx330,the original tires 235/55/18 was replced with yokohama geolander 255/55/18,,,how safe is it to drive hundreds of miles thanks
Old Dec 25, 2009 | 08:56 AM
diverchris's Avatar
diverchris
did you get an alignment with the new tires to ensure that over your trip you do not experience any uneven tire wear. Also since the tires are wider you may need to reset to speedometer.
Old Dec 25, 2009 | 08:59 AM
shikbas's Avatar
shikbas
thanks,waht you mean by resetting the odometer,and how thanks
Old Dec 25, 2009 | 04:45 PM
catdaddylo's Avatar
catdaddylo
I think diverchris is thinking because your tires are wider this may cause a false speedometer reading. Since the tires you are replacing are the same diameter of 18 inches the wider tires should have no bearing on speedometer accuracy. I would not worry about it.
Cat
Old Dec 25, 2009 | 05:17 PM
jfelbab's Avatar
jfelbab
Cat
Not true. The tires aspect ratio is changed hence the diameter is changed. Sure, the wheel size has not changed but the tires are not just wider but taller as well. The 255/55/18 size will have your speedo reading about 3% slower than you are actually traveling. At 60 MPH you will actually be traveling close to 62 MPH. True, 3% is no big deal but if you tend to push things and think you are running around 8 MPH over the posted limit you could get a ticket as you are really running 11-12 over.
Old Dec 26, 2009 | 06:59 AM
mandyfig's Avatar
mandyfig
255-55-18's are fine. Just note the slight speed change. Go enjoy your trip.
Old Dec 26, 2009 | 07:07 AM
tromly's Avatar
tromly
Yes the tires are just fine, hope you have a great trip with no stops by the police !! Yokohama builds a great tire !
Old Jan 2, 2010 | 03:00 PM
shikbas's Avatar
shikbas
hi,thank you all,every thing went fine but the heck of rattles,new one came from the dashboard which was removed by the dealer before to fix rattles and the squeeky clicky driver seat which was there and the dealer refused to fix since they could not duplicate
Old Jan 2, 2010 | 03:13 PM
salimshah's Avatar
salimshah
25 Year Member
Attempt to fix behind the dash at times makes the matter worse. I would only recommend a fix if the noise can not be tolerated.
At this stage, you need to demonstrate the noise to the tech and let him make as many efforts as needed to fix the problem.
Salim
clambros
Apr 27, 2023 10:47 PM
RX330inFL
Nov 13, 2011 03:30 PM
jeffyjeff
May 24, 2008 08:32 AM
chuuck1e
Dec 16, 2005 09:16 PM
slawek65
Wheels, Tires & Brakes Forum
Nov 19, 2004 01:59 AM
