Rx 350 2008 airbag light on!
Hi....I just got my RX350 2008 battery dead....I tried a jump start and it worked but the airbag light now is on!!!
Any advice to switch it off?
Thanks
Thanks
Take it to the dealer, pronto!!!
Try disconnecting the battery for 20 minutes or so [you will loose your memorized settings]. If this does not clear the air bag light, you should go to the dealer.
Also search the SC forum as the air bag on is set by having the key in ignition and disconnecting the instrument cluster. They may have a way of resetting that condition listed in there.
You should have it checked out ... just in case this is not a warning light gone astray, but a real problem.
Salim
Salim
There has been a rash of batteries failing recently. Mostly 07's and 08's. We need data collected.
