Luggage cargo cover question....
Silly question but how do you connect the hook of the cargo cover between the headrest do you just force it? It hurts my fingers is there an easy way?:uh:
If I'm understanding your question, you are asking about connecting those U-shaped clips to the uprights of the rear seat headrests. You may need to lift the headrests up from the seatback to expose an inch or so of the support rods, then just push the opening in each clip over the rod. It takes a little force to do it, but it shouldn't be too difficult. You can push the headrest back down when you have secured the connection.
Incidentally, I've found that little hammock formed between the rear seatback and the roller of the cover makes a handy place to keep my big golf umbrella that's too big to share the cabin with me. ;) |
Yes that is what I am trying to do... I was doing it right then. It just too hard the u shaped it's solid but I will give it try tommorow. Thanks
Interesting tip about the golf umbrella. I keep mine on the handles under the rear seats that you lift to slide the seats forward or backward. Experience teaches, however, that a velcro tie is required to keep it from rolling out onto the floor. The only advantage here is that it is out of sight, but I like the hammock tip, and may try that for a while, especially now that the rains have begun.
