Programming 2004 RX330 Transponder Key
Hello,
Ive searched and searched but yet to find success on a DIY. Does anyone have instructions how to program the transponder for the 2004 RX330? Thanks in advance. :woot: |
this might work but not 100% sure!!!!!!!! use at your own risk
TOYOTA – LEXUS “PEDAL DANCE” PROGRAMMING PROCEDURES Of primary importance is determining if you have a key that is enrolled in the car’s computer as a “master” key or a “valet” key. The procedure for making this determination is: 1. Positively locate the “security” or “anti-theft” light. This light should blink when there is no key in the ignition or if an unrecognized key is placed into the ignition. 2. Insert the key you have into the ignition – DO NOT TURN ON. There are 3 possible things that may occur: (a) Security light continues to blink = unrecognized key. (b) Security light goes off IMMEDIATELY = MASTER key (c) Security light remains illuminated for 1-3 seconds before going out = VALET key If you have only a VALET key or an unrecognized key then the ECM will have to be reprogrammed or “flashed” before you are able to add any more keys to the vehicle. Once you have determined that you have an enrolled MASTER key you may proceed to either: (a) delete all other keys from the car’s computer (b) add an additional MASTER key to the car’s computer. (c) add an additional VALET key to the car’s computer. PROCEDURES FOR PROGRAMMING A - Delete all keys other than present master key 1. Make sure all windows are rolled up and all doors are shut. 2. From outside the car LOCK the car door with the key. 3. From outside the car UNLOCK the car door with the key. 4. Enter vehicle and close the door. 5. Start the car’s engine. 6. Turn engine off and remove key. 7. Place master key in the ignition lock. (DO NOT TURN ON.) 8. Within 15 seconds press and release the gas pedal 6 times. 9. Within 20 seconds, forcefully press and release the brake pedal 7 times. The Security light will blink. 10. Within 10 seconds, remove the master key. All other keys should be deleted from the car’s computer. B - add an additional MASTER key to the car’s computer 1. Make sure all windows are rolled up and all doors are shut. 2. From outside the car LOCK the car door with the key. 3. From outside the car UNLOCK the car door with the key. 4. Enter vehicle and close the door. 5. Start the car’s engine. 6. Turn engine off and remove key. 7. Place master key in the ignition lock. (DO NOT TURN ON.) 8. Press and release the gas pedal 5 times. 9. Forcefully press and release the brake pedal 6 times. 10. Remove key 11. Place new key in the ignition lock. (DO NOT TURN ON.) 12. Press and release the gas pedal 1 time. 13. Wait (about 1 minute) for security light to stop blinking. 14. Remove new key from the ignition lock. 15. Press brake pedal 1 time to close programming cycle. 16. Wait 15 seconds for programming cycle to end 17. Insert new key into ignition lock and start the vehicle. C - add an additional VALET key to the car’s computer 1. Make sure all windows are rolled up and all doors are shut. 2. From outside the car LOCK the car door with the key. 3. From outside the car UNLOCK the car door with the key. 4. Enter vehicle and close the door. 5. Start the car’s engine. 6. Turn engine off and remove key. 7. Place master key in the ignition lock. (DO NOT TURN ON.) 8. Press and release the gas pedal 4 times. 9. Forcefully press and release the brake pedal 5 times. 10. Remove key 11. Place new key in the ignition lock. (DO NOT TURN ON.) 12. Press and release the gas pedal 1 time. 13. Wait (about 1 minute) for security light to stop blinking. 14. Remove new key from the ignition lock. 15. Press brake pedal 1 time to close programming cycle. 16. Wait 15 seconds for programming cycle to end 17. Insert new key into ignition lock and start the vehicle. |
Everything else on the internet failed (including the procedure posted above), but this procedure worked for me on my 2006 RX330:
http://imgur.com/r7xbf Hopefully this helps someone else. |
Programming chip key for 2004 rx 330
I have tried the instruction on the site to program my key but have been unsuccessful. Are there any other methods of programming the key?
My 2005 rx330 came with only 1 key. So I have been thru this.
There are 2 components to programming the key: 1) programming it to lock/unlock and the rear liftgate 2) programming the key so the engine will start (transponder-ecu) I only had luck with a genuine lexus transponder (and key), got it on fleabay from a lexus dealer. I then got the key cut, and then programmed the the lock/unlock and rear liftgate. The key would turn but not start the car. nada. nothing. the engine didn't turn over. Then some where on the forum I found a post with this: $15. since I had 1 key already, I could use this gadget, and it was programmed in less than a minute (the second key). very easy. I would send you mine, but it would probably be cheaper for you if you ordered it direct if you have amazon prime. Hope that helps. |
Check here
Awesome.
Originally Posted by Lilant
(Post 9921937)
Thanks
You guys are awesome. Had this happen to my 23 gx yesterday. Same symptoms fob buttons don’t work. Drove the the dealer. Told them what to do. Tech never heard of this He pulled it up turned it back on. All is good now
thanks!!! |
