Ongoing RX Issues
1)as far as condensation, sorry poor sealing, there is no modified parts, just have them warranty them.
2)roof drip moldings, new modified ones just came out. ask for the new ones with adhesive tape, not old stock.
3) rear wiper, you need to you lots of fluid to clean off dirt. was there ever any damage to the rear tailgate or window?
4) seat belt- does it retract slowly, or not at all.
5) tire pressure light- any wheel bearing noise? mismatched tires(manufactured in different countries, same brand and model).
6)how often does your abs/vsc light come on, does the speddo work when the light comes on?
7)the mirrors will only tilt down a preset amount, no special setting required. try tilting them down, then put the car in reverse(you will hear the mirror bottom out)
2) thx for informing me of the new moldings. I will defenitely have them replaced with the new types.
3) there is no damage to the window
4) sometimes the belt stops retracting half way or so and just hangs. then you wind up hitting it with the door when you close it if you don't pay close attention
5) Wheels are all factory, no bearing noise, no indication of any problems
6) The abs/vsc/tpm lights come on totally at random, usually a few times a week, dry weather and wet weather. I haven't noticed the speedo not working so I'm assuming that it is. The truck is at the dealer right now. I brought it in Saturday morning. So far they are telling me that a intermittent shortage in a break switch is causing the lights. and as far as my handling issues, they are telling me that everything (allignment, brakes, etc) are all within specs. I'm suppose to pick up the truck tomorrow (mon).
I did score an 07 rx350 loaner though (o:
I've tried manually setting the reverse tilt but this has had no effect.
nymav, I too have had quite a number of problems with my RX330 which i purchased in Jan 2005 as well!! Interesting ... did you get it from Prestige in NJ?
here's going through your issues and adding my own:
1) had the condensation problem as well. they took a while to replace it since the part wasn't available but it was done (and they gave me a rental)
2) have the roof molding problem as well, didn't know there was a fix so I'll be sure they replace it next time I'm in
3) rear wiper => the TSP fixed it so be sure to have that applied to the car as well.
4) Transmission replaced after 23k miles. Had ticking noises come on after you let go of the pedal at low speeds (below 45 mph). They never saw this and had to replace the entire transmission since Mother Toyota (japan HQ) asked for the transmission in its entirety since they hadn't seen the problem before.
5) Now for the ABS/VSC/BRAKE/TIRE PRESSURE light ... I just had this problem. Have them replace the "Brake Switch" It sits behind the brake pedal. After I had this replaced it was fine.
I hope that helps!!
