View Poll Results: What gas do you put into your 2RX?
Premium
0%
Medium
0%
Regular Unleaded
0%
Voters: 0. You may not vote on this poll
Do you need Premium Gas in the 2RX (merged discussion threads)
Old 11-24-14, 12:08 AM
  #616
rxonmymind
rxonmymind's Avatar
As an individual I don't give rip about fuel. Never have. BUT it's finally encouraging to see it below $3 a gallon for small businesses & big. Talk about economies of scale! Go USA.
Old 11-24-14, 04:42 AM
  #617
BensonRX
BensonRX's Avatar
Originally Posted by jfelbab
After 1 year (about 9,000 miles) in my 2014 RX350 AWD. I'm still mostly using regular as the cost of premium (+$0.40/gallon) makes the added fuel economy not worth the cost. I also have not used 91 octane but a few tanks so the graph is not cast in stone.
Well, based on your numbers, you got a 15% increase in mpg while paying ~10% more for premium. I think you should run a few more tanks to see if the data holds.
Old 11-26-14, 06:52 AM
  #618
Gitchiesus
Gitchiesus's Avatar
That's an awesome chart. I'd be curious to see more data too! Please come back and update everyone.
I was looking for moreless people's opinions....
If Premium is "recommended"....than you have a choice...
If premium is "required"....than you have no choice....
It's like if your car doesn't need synthentic oil.....but you put it in because its better? Is it really?
That's basically what it boils down to.
I was looking at a few older RX models 06-08, it'll be a kid mobile, here there, a lot of running errands kinda car....needing to replace the againg A4 we have....so I wasn't too concerned about performance, hence why this RX would be a decent choice.
My mdx and tiguan both require premium, so I thought it would be nice for a change to use regular gas for a running around car....
Again, I don't wanna hear "its a lexus", just use premium....c'mon at the end of day, its old like a 2007 etc..., its cheap...it'd be different if it was a brand new model. which I believe those ones are "required premium" gas.
Old 11-26-14, 07:12 AM
  #619
takeshi74
takeshi74's Avatar
A lot of vehicles that require premium can temporarily run on non-premium and some find that they can routinely use non-premium without adverse effect.
Might be, might not be. All depends on the specifics but you are correct in that it's not simply/universally better. A car doesn't have to "need" synthetic to benefit though.
Old 11-26-14, 07:13 AM
  #620
thomas1
thomas1's Avatar
Funny we try to save on a gallon of fuel while buying bottled water and coffee at Starbucks for a premium....Just saying.
Old 11-26-14, 08:43 AM
  #621
jbl-1985
jbl-1985's Avatar
A long time ago I used premium in all of my cars. Note that none of them require it. I never saw any increase in mileage whatsoever.
Old 11-26-14, 09:03 AM
  #622
UCF3
UCF3's Avatar
I've been alternating between Regular and Exxon/Shell Premium(93). No change in mileage.
I did reset the learning ability of my car and so far i'm not filling my tank half as much as i used to compared to when i bought my RX35 three months ago. I also removed the cross-bars from the roof-rack, and put on new tires with Nitro and i think that helped with an approximate change 19-22mi/gallon to 24-26mi/ gallon.
After resetting the ECM i stopped over-pressing the gas pedal for hard-accelerations and let the gears change at its pace. That helped too. Slightly bent the front tag on the RX to match the front fascia.
Old 11-29-14, 07:05 PM
  #623
BensonRX
BensonRX's Avatar
My experience has been with cars that require premium -- in those cases, I've noted a decrease in mileage when using less than premium. Since it is suggested in the RX, I'm running the same experiment to see if I get similar results.
Old 11-30-14, 03:11 PM
  #624
roadbike56
roadbike56's Avatar
I've been blissfully ignorant of the Premium requirement. Thank you for bursting my bubble.
Old 12-01-14, 01:17 PM
  #625
Gitchiesus
Gitchiesus's Avatar
That is true in some vehicles....I'd hate to see what they would run like....like my A4 1.8T or my Tiguan 2.0T
2 weeks ago, I had put premium from like an Esso gas station....car ran like garbage!!!
I normally always go to Shell...always, even if I gotta drive out of my way....
I don't think its about people here trying to save money, I think maybe bringing better light to the "recommended" fuel vs the "required" fuel topic.
As for my conversion...I think this weekend, filled up the Vw Tiguan, with about 8th left, it was $75 dollars here...the conversion dollar would have been $66USD, but prob even less if I was filling up across the border.
I think its been a great marketing ploy for them, like someone mentioned earlier, their 2005 rx said 87 was fine, but for 2006 model year, it suddenly said 91. What could have changed? I've noticed a lot of cars from 2006+ seem to suddenly recommend the 91, so what happened in 2006, is this when the big gas companies starting lobbying more to the car manufactures........
Old 12-01-14, 02:31 PM
  #626
jfelbab
jfelbab's Avatar
It may also be that the manufacturers are using every trick they can to help meet the government CAFE standards for fuel economy. Both of my Lexus vehicles get better fuel economy with premium. If the manufacturers can report just a single mpg better cafe results by simply mandating premium fuel in the OM, they might be able to defer some retooling costs. A one or two MPG increase may not seem like a big deal to you and me but to the manufacturer it may translate to a good deal of money.
Old 03-20-17, 06:26 AM
  #627
ajay60610
ajay60610's Avatar
Default premium gas
Is premium gas worth the extra cost....is 90 cents higher per gallon in suburbs of Chicago,Ill....have 2009 RX-350 AWD with 117.500 miles
Old 03-20-17, 06:41 AM
  #628
05RX330AWD
05RX330AWD's Avatar
I fill up with Premium 91, performance is better & this grade of octane fuel (in Canada) contains additives to avoid deposit build up.
According to the Manual....
Attached Thumbnails Do you need Premium Gas in the 2RX (merged discussion threads)-capture.png
Old 03-20-17, 07:14 AM
  #629
joedaddy1
joedaddy1's Avatar
90 cents is crazy..
how much less for mid-grade?
Old 03-20-17, 08:35 AM
  #630
pablo87
pablo87's Avatar
I have a 2005 RX (so different engine) and have found the regular fuel perfectly fine. Any sluggishness could be mainly attributed to a dirty throttle body and mass airflow sensor.
Quick Reply: Do you need Premium Gas in the 2RX (merged discussion threads)
