Thanks for all the replys. I will get them soon. I have about 30% left on the michelins. Its been raining like all week and my wifey said she dint feel too safe driving with those. I will post pics as soon as they are on.
Hi,I got those 5 mm spacers,realy i am scared to install on the car,the way they look very thin is it safe to install
Good thread with lots of useful information - thanks to all who have contributed. I was worried about finding replacement tires I liked in the oddball stock size, but now I'm comfortable with our future replacement being Nokian WR 255/55 R18.
A question: Are folks buying 5 tires, so that the spare will match or are you keeping the stocker as the spare? Just to add to the whole sizing discussion, it is important for people to realize that the true size of a tire is not always exactly accurate. For example, a 255/55 R18 tire diameter could vary from say 28.8" to 29.2". |
Hi ,any buddy who did the 255/55/18 with spacers had to do allignment,,,thanks
Hi cooradomr2,after installing the new tires and the spacers did you have any troubles with balance and steering wheel vibration thanks
Can I put 255/55 R18 studded snow tires to my Lexus R350?
Originally Posted by thekat
(Post 2405978)
I just put 255/55/18 Bridgestone Dueller Alenza on mine last week..
Did not use spacers.. From what I could tell, I don't have any rubbing.. Rubbing was reported to happen when the wheel was turned all the way.. No rubbing that I could hear/see.. The Bridgestones have a bit stiffer ride than the Michelins (could be the air pressure - 36 lbs) but also about 300 less.. I got them on sale.. buy 3 get one free.. the local Tires Plus matched the Firestone Store price.. Thanks!! |
fyi, if you like the look of the BMW X5 wheels/tires... here is a good reference page https://tiresize.com/tires/BMW/X5/
2008 rx400h
I put on a set of Michelin Latitude 255/55/R18 H105 on my 2008 RX 400H. These tires fit perfectly with no rubbing of any kind and required NO spacer. They mounted perfectly to the original wheel and mounted back onto the car as they were meant for it from the factory. The results: this vehicle had some inexpensive 235/55/R18 tires that did not perform well in the rain and had a lot of road noise. These new Michelin's are just amazing, quiet ride,better handling and pumps out water from the three deep channel treads during heavy rain. On a scale of 1 to 4 I'd rate them a 4+! I very much like the more aggressive stance the vehicle now has with the overall larger tires. Yes, they are over very expensive at well over $200 each but if you have the extra cash you'll be very happy with your spend. Michelin is currently running a $70 rebate per tire!
https://cimg6.ibsrv.net/gimg/www.clu...3c120a9a8c.jpg |
Congratulations on the upgrade guys. Quick question: Did you guys replaced the spare as well ? I was wondering if I upgrade the 4 tires and if it's worth upgrading the spare as well since my rx350 is awd. Late by 7 yrs since the last 😆 . Recently bought Rx350 as a back up and notice I love everything so far beside the brake system is underperformed. Definitely wider tires will help with the stability and traction as well. Thanks
Two different diameters, & as well as being awd, yeah....Best to swap out the wheels to at least a 8.5'' x18....use a 20mm offset & yeah the 8.5's will take a 235. The 255's work better w/ a 9''-9.5'' width wheels.....Plenty of room w/ the rear struts....
You don't need an expensive spare to match the four that are on the car, but tires deteriorate from age as well as wear. If the spare is fairly old, you should consider replacing it with one that will not fail as soon as you mount it on a wheel. Check with a trusted tire store to see what they say about the age of a spare, bearing in mind that it is in their interest to sell you a new tire.
Originally Posted by tfischer
(Post 11512018)
Add Wheel Spacers to get the rims to stick out the fender well. I used 1/2" Front and 1.5" on the rear. Looks flush.
Originally Posted by mandyfig
(Post 11514491)
