climate control question
Old Feb 9, 2004 | 07:01 AM
1st330's Avatar
1st330
10th Gear
Default climate control question
Hi,
Last night I drove my rx330 at highway speeds for the first time in a long while. Good news -- it was a pleasure to drive under highway conditions, and my mpg went up to 21.5 mpg. Bad news -- the climate control (on auto) seemed to behave strangely. It was 40 F outside and I set temp to 71F. At first the climate control seemed OK on auto. Then I noticed it was getting cold in the cabin, and the vents were blowing cold air. I turned off the climate system and then on again, but it didn't seem to get better until I was able to turn the engine off completely. Even now it seems fickle, seems to blow either hot air or cold air. Am I missing something? Thanks for reading this.
Old Feb 9, 2004 | 08:59 AM
MugenRD1's Avatar
MugenRD1
I had the same issue so I just turned the auto off and increased the temps to around 82 degrees and finally hot air was blowing...
Old Feb 9, 2004 | 11:14 AM
mooretorque's Avatar
mooretorque
Talking
There may be nothing wrong with your system. Your AUTO setting was 71 F., which is quite cool, esp on a day when no radiant heating is involved. On a summer day, you'd have had a gale of cold air from the vents as the system worked to keep the cabin cool, but on a cool day such as you describe, you'd still end up with a pretty cold mix for vehicle temp of 71....................
Lveyolfe
Oct 10, 2017 05:07 PM
hovbuild
RX - 3rd Gen (2010-2015)
Dec 28, 2014 04:38 AM
LIS350A
May 18, 2008 06:30 AM
agc
May 2, 2005 06:36 PM
lexusnexus
IS - 1st Gen (2001-2005)
Nov 11, 2002 04:23 PM
