Starter Button for pre-lube
Old Apr 28, 2025 | 05:27 PM
Felix's Avatar
Felix
A good possibly is the valve covers gaskets need replaced & the vvti O-rings come w/ the valve gasket.
Old Apr 29, 2025 | 04:52 PM
Clutchless's Avatar
Clutchless
See this video regarding what this mechanic did to stop the death rattle without tearing the engine apart. It is similar to what the OP figured out.
Old May 11, 2025 | 10:57 AM
2grfebeliever's Avatar
2grfebeliever
10th Gear
Awesome video Clutchless!
Another dozen cold starts later and still no rattle, and my rattle was BAD. It had to have been the timing chain rattling around from a loose timing gear system due to no oil in the vvti cam gear. I always worried about it causing major damage. I'm so glad it is fixed
The original thing that clued me into the typical approach missing something big was when it first started happening and I kept the rattle at bay for months just by putting the key in the ignition and turning the car on without starting it, and letting it sit like that for a minute or so. If I did not do that it rattled every time and if I did do that it rarely or never rattled for months, and it got progressively worse until it rattled every other time no matter what. Then I started pulling the fuse to fill the vvti cam gear with oil using the starter, which worked great aside from burning through a starter (easy replacement), and now it is fixed all together. I highly recommend this repair to anyone. Here is a GREAT detailed video to help.
Teamrpr
Nov 15, 2020 04:40 AM
MrMark
Oct 13, 2014 10:30 AM
DCogswell
May 30, 2011 11:45 PM
jimmy2x
Jan 12, 2011 12:18 PM
redtoesblue
Jul 19, 2005 05:07 PM
