New tires?
Old Jan 6, 2024 | 09:05 AM
Xman1951's Avatar
Xman1951
1st Gear
Default New tires?
I'm considering a 2009 RX350 with 200k miles from a private seller. I ran the Carfax report the current owner (4+ years, 100k miles) is replacing tires every 25K miles. Seems to indicate an underlying issue. Suspension maybe? In 2019 at 114k "sway bar links, front struts, front strut cartridges replaced." In 2020 at 127k "wheel bearings/hubs replaced." I realize not all tires are created equal but this is a concern. On a (maybe) unrelated topic...thoughts on Car Shield extended warranty? Thanks.
Old Jan 6, 2024 | 02:14 PM
Leeper's Avatar
Leeper
At 200k miles you'd be well overdue for LCA's and ball joints. Tires every 25k seems excessive but you don't know about the alignment, driving habits, etc so no one can answer your questions
Regarding any aftermarket extended warranty - there is zero chance I'd ever consider one
Old Jan 7, 2024 | 05:08 PM
Felix's Avatar
Felix
Ditto as I'd be looking at replacing the A-arms which come complete w/ b/j's & bushings.....Don't go cheap here.....
Old Jan 8, 2024 | 07:08 AM
kamlung's Avatar
kamlung
does the carfax or maintenance records show an alignment being done? at 200k miles just be prepared to replace a few suspension components that have aged out and then get an alignment...
Old Jan 8, 2024 | 04:22 PM
cdnewton's Avatar
cdnewton
The AWD RX is hard on tires, period.
We have over 300,000 miles on ours and up until the Michelin Defender LTX MS, the longest set lasted 42k (I have tried six different sets of tires).
-The first OEM Michelin MXV 8 set lasted 26k (in 2004/5).
I have been impressed with the Defender as the current set is going on 50k. Unfortunately, they quit making the 235/55/18 size, so I will be back to tying to find another tire that can last.
Old Jan 9, 2024 | 07:13 AM
kamlung's Avatar
kamlung
i think it also has to do with low inflation that lexus recommends from the factory. IIRC it's 30, which always felt low to me... i usually keep mine at ~35psi
Old Jan 9, 2024 | 05:58 PM
Leeper's Avatar
Leeper
Very good point Kamlong, not only will it increase longevity it will also give better MPG... the con is a slightly more harsh ride. Tire shops will try to tell you it will lead to improper tire wear they are incorrect
Old Jan 9, 2024 | 08:28 PM
tomr51's Avatar
tomr51
i run 38lbs front and rear and get good even tire wear all round
Old Jan 10, 2024 | 10:50 AM
kamlung's Avatar
kamlung
this is good especially in the winter when ambient temps are lower and you want a 'higher' sidewall for any snow driving...
Old Jan 10, 2024 | 03:54 PM
cdnewton's Avatar
cdnewton
I run 36psi, tires always wear very even, but traditionally have needed tires every 40k (or less). Like I mentioned, after 305k, I just think the RX AWD with 18" is hard on tires.
Old Jan 11, 2024 | 06:03 PM
Felix's Avatar
Felix
I'd be going 255's.......
TrentYoung
ES - 7th Gen (2019-2025)
20
Feb 12, 2022 06:30 AM
tarponman
RC F (2015-present)
18
Feb 22, 2016 05:51 PM
texas008
Nov 23, 2015 07:31 PM
omarg
Mar 29, 2013 09:01 AM
bam
Feb 6, 2006 08:35 AM
