Catalytic converter going bad? (Temp).
Old Nov 18, 2023 | 01:10 PM
fabchef's Avatar
fabchef
Default Catalytic converter going bad? (Temp).
Hi gang, hope you are all doing well? I think was thinking about this the other day. I'm not really getting any cel codes, not sulphuric smell from exhaust. Sometimes at highway speeds i'm not sure if it's the state of the road itself, but feel a slight "jerky" motion.
i decided to take a laser thermometer and check temps of the secondary car (one before the muffler , under passenger seat). The engine was warmed up and at idle. I tested pipe section before cat, and was around 190-200 celsius. I then tested at centre section of cat AS well as pipe after cat and they were around 160-169 degrees celsius. Is this normal? Does this sound like a healthy cat?
Old Nov 18, 2023 | 01:43 PM
Mesquite77's Avatar
Mesquite77
Are you sure it is a cat? Some models/markets have a resonator there I think...
Old Nov 18, 2023 | 04:49 PM
fabchef's Avatar
fabchef
Mesquite.....
yes, it's the secondary Cat. Basically...the two cars meet at the collector...which has a flange. The next section is a flange followed by the secondary cat (no 02 sensors). After this there is the mid muffler and after that is the rear muffler.
the other thing that can be effecting my gas mileage is that I installed my winter tires 2 weeks ago. The tires are on steel (honda) rims that weigh a tonne!
So when i was taking the temp readings, it was from that secondary cat.
is it normal?
fab
Old Nov 18, 2023 | 05:10 PM
I suspect your temp reading is not accurate. Watch real time fuel trims as you drive and report back.
Old Nov 18, 2023 | 05:40 PM
fabchef's Avatar
fabchef
Lex2k....
i have an obd scanner. Remind me...what's the best way to take the readings (ie: cruising at 100km/h....see what short-term and Long-term readings are)???
sertimins
Mar 27, 2021 06:04 PM
Wombat58
Performance
May 20, 2017 08:06 PM
jbruffett
Sep 28, 2012 11:43 PM
mrshabo
Nov 25, 2004 03:19 PM
HotBoy
Jan 22, 2004 08:49 AM
