Please Help Check Engine VSC
Old Apr 5, 2023 | 02:23 PM
Rdoktbr's Avatar
Rdoktbr
Angry Please Help Check Engine VSC
Hello, I wouild appreciate any help in resolving issues with my 2nd. gen. RX.
Vehicle - RX350 2nd gen 2007, AWD. 330K highway miles.
2021-22 Replaced - NGK plugs, Denso coils, Battery, Alternator, MAF sensor, Front drivers side bearing, Steering rack, 4 shocks, 4 brakes pads and rotors and
Tail lamps (car doesn't like LED's). Ignition coil cable connectors are brittle but mechanic applied non conductive silicone to hold them in place.
After all this, the Check Engine/VSC light came on and the engine would essentially stall but ONLY when in stop and go traffic. I switch the engine off for about a half hour and it starts.
Code said something about 2nd cylinder misfire so I replaced that ignition coil but the problem persists again only in stop and go traffic. At highway speeds the car RUNS FINE even with the
check engine light on. Since it seems to run fine on main roads and highways I would like to keep it going. Everything else works just fine.
Thank you for your time and help is assessing the root issue.
Old Apr 5, 2023 | 02:41 PM
Where did you buy the coils, are they actually Denso? I ask because the market is infested with fakes. Would be nice to know the exact code. My hunch says your charging system is flaky due to the alternator.
Old Apr 5, 2023 | 06:59 PM
Felix's Avatar
Felix
Have you switch a couple of coils around? Is the gap of the plugs good?
Old Apr 6, 2023 | 05:28 AM
hansgruber's Avatar
hansgruber
3rd Gear
Mine was resolved yesterday at the dealership by replacing the purge valve (whatever that is!!)
Old Apr 7, 2023 | 05:41 AM
hansgruber's Avatar
hansgruber
3rd Gear
I lied!! CEL is back again!!! :-(
Jbakyy
Jun 2, 2022 06:59 PM
Rdoktbr
Mar 24, 2022 04:32 PM
Calidream
Jul 21, 2020 12:10 AM
oscar55773
Jan 17, 2017 03:24 PM
gs9351
Mar 20, 2009 10:28 AM
