ClubLexus - Lexus Forum Discussion (https://www.clublexus.com/forums/)
-   RX - 1st Gen (1999-2003) (https://www.clublexus.com/forums/rx-1st-gen-1999-2003-182/)
-   -   Steering help..Lexus tech's... (https://www.clublexus.com/forums/rx-1st-gen-1999-2003/912062-steering-help-lexus-techs.html)
xcursion88 Feb 19, 2019 11:13 AM
Need some quick information. Changing a rack on a RX300 2001 variety....the steering wheel may or may not have rotated a full revolution.
This happened with the rack unattached. My question is what is the clock spring like in this steering wheel and will this be an issue.
If so is there a way to find the true center of the wheel from a rotation point of view?
Thanks in advance for any replies to this.
maxSteel Feb 20, 2019 09:22 AM
I don't see any "clock spring" in the steering column assembly.
There is a "Spiral cable" that is part of the Combination Switch assembly. Looks like it is on the steering column behind the steering wheel.
Before putting the steering wheel back on you are supposed to center it.
It says
  • Check the front wheels are facing straight ahead
  • Turn the spiral cable counterclockwise by hand until it becomes harder to turn
  • Rotate the spiral cable clockwise about 2.5 turns to align the marks
It also says the spiral cable will rotate 2.5 turns to either left or right of center.
Given that, if you haven't disassembled the column perhaps you can just carefully rotate the steering wheel counterclockwise until you feel the spiral cable limit and then rotate it clockwise 2.5 turns to find your center.
salimshah Feb 20, 2019 07:11 PM
Too late now, but just in case another member removes the rack, first thing you do is center the steering wheel. Strap the wheel to the seat belt [buckle ups the belt] and tie in to hole in the steering wheel, so that you can not mistakenly turn it [slight motion is ok, but you should not be able to loose your straight ahead location].
Salim
