Front Right CV Axle
Front Right CV Axle
Hello everyone. Love the forum. Oklahoma based long time reader, first time poster.
Will make this post sweet and simply.
Just this past weekend I changed out the sway bar links on the wife's 2000 rx300 AWD with 243K...only to find a cracked CV axle boot on the front passenger (right) side. What parts vendors (other than Lexus/Toyota) might anyone recommend, had good success with, recommended videos I might watch before tearing into it?
We do plan on keeping the vehicle. Any and all information is greatly appreciated. Thanks again for the assistance.
SilverRX30 (01-18-19)
I dont know any good aftermarket boot kits. Im sure there are good ones out there.
Some even zip kits so you dont have to take the axles out.
Just dont know how they hold up.
Personally, id use OEM boots. It cost more but you know they will last.
If the boot lasted you 200k+, a replacement OEM would fair well since you mentioned keeping the vehicle for a while.
Only draw back is, its messy, a lot of 4 letter words will fly while working.
Not sure how mechanically inclined you are but it would be a challenge if you havent done one. No offense.
Semi special tool needed as well.
Snap ring pliers. CV boot compression pliers.
Have you ask a shop how much they would charge?
https://www.clublexus.com/forums/rx-...r-cv-boot.html
I replaced the boot on RX and in a year had to do the other side. I think I posted a DIY.
If you want 50k + miles (estimate) then just by the shafts. If you want another 150K miles, buy the kits. Just dont stretch the cv joint [I had a heck of time collecting the ball rollers and assembling the joint ... incorrectly first and then the right way. Having a vise was a great help].
Salim
Salim
Just replace the axle. Axles are cheap and aftermarket boots are not serving long. Also, if you go with a split boot, that is quite an adventure to put on. Now, I think, the right side is the long one, right? That's pain to replace.
Someone makes boots that stretch over the CV joint and then snap in place. At least use that one, if axle replacement is not an option. I can't remeber, where I posted video to that boot...
here ya go
https://www.stretchcvboot.com/cv-boots/
here ya go
I rebuilt mine as I was bent on keeping my Lexus OEM, down to clips and screws. And I enjoy doing the work .. as well as suffer the consequences.
Salim
Whoa!! My bad!! I didn't even consider anyone would think I simply wanted to replace the boot. After nearly a quarter of a million miles?!? I would expect to replace the entire axlet.
My inquiry was more towards what vendors, name brands might be recommended? I see various names on RockAuto and 1A Auto. Who trusts what? Who swears by what? That's what I was inquiring about.
I called the local Lexus dealer just today and was quoted $1200+ dollars for the part. Yea...Nope! Not happening. Additionally, is an AWD axle different from the FWD?
As to "mechanically inclined," I'll let you tell me if you think I can do it. I currently do or have done:
* Brakes * Strut inserts * Multiple alternators * Multiple starters * A harmonic balancer * At least two tuneups on this Lexus (and we all know what a pain it is getting to the rear spark plugs). I even spent an entire Saturday replacing a rack and pinion on a Toyota Camry. I'm not as handy as some of you, but I'm definitely trying to get there.
Thanks everyone.
Thanks everyone.
Thanks everyone.
Thanks everyone.
Nuff said. Lol
Poppin a new axle then would be cake.
Dont forget to take the 10mm bolt out for the abs wire bracket so it doesnt get stretched out while pulling out the axle shaft.
AWD and FWD axles are different.
