Go Back  ClubLexus - Lexus Forum Discussion > Lexus Model Forums > RX Models > RX - 1st Gen (1999-2003)
2002 RX AC,screen, radio and temperature gauge not working >
Old 01-02-19, 11:03 AM
Tigerblue7
Default 2002 RX AC,screen, radio and temperature gauge not working
AC,screen, radio and temperature gauge not working! Help
Tigerblue7 is offline
Old 01-02-19, 12:33 PM
salimshah
Check the fuses.
Salim
salimshah is offline
Old 01-02-19, 01:01 PM
Tigerblue7
Default Lexus 2002
fuses ok and changed out screen and still does not work. What next help
Old 01-02-19, 03:12 PM
Nad1370
Nad1370's Avatar
Well on the radio side, you mentioned you checked all the fuses.
Assuming you just didnt pull out and looked at the fuses and used a test light or some sort to check if you actually got power flowing to those fuses with the key ON.
Next is to check if you have power going into the radio.
The multi screen display gets its power from the radio.
No power to the radio = no screen display.
Also check grounds as well.
Without ground, the radio will not work either.
Temp gauge and/or AC might be on a different circuit but im not 100% sure.
Nad1370 is offline
Old 01-04-19, 10:30 AM
Tigerblue7
Default Lexus 300rx 2002
Mechanic took radio out and checked all fuses and wiring. When he put radio back it worked. Still no AC , tem gage and no screen. Mechanic changed screen out and still did not work! Help Help
Old 01-04-19, 04:32 PM
Nad1370
Nad1370's Avatar
2 fuses you need to check for the Nav screen.
10 amp dome
7.5 amp Radio no.2
If those 2 fuses are good, your mechanic needs to check if there is power flowing to the nav unit.
He needs a wiring diagram to pin point which power wire it is to the nav connector.
This would be my next step if it was me.
Nad1370 is offline
Old 01-07-19, 09:09 AM
RX469
To clarify, when you say the mechanic changed the screen out, do you mean he changed out the actual LCD screen or the whole assembly unit?
RX469 is offline
Old 03-12-19, 08:54 AM
Tigerblue7
Default Radio and ac. Door locks not working!
checked all fuses and are ok. Went to dealer and found out it was a ground wire that was the problem. Said it was water on it . $500 repair and all is ok. In case anyone has the same problem
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
