Door lock actuator?
Did all Lexus models made around 2001 use the same door lock actuators? What about Toyota's?
Originally Posted by Phil01
(Post 10390712)
OE Num: 69040-48020 69120-30010 6904048020 6912030010(Front Left) 69030-48020 69110-30110 6903048020 6911030110(Front Right) 69140-30110 69060-48010 6914030110 6906048010(Rear Left) 69130-30110 69050-48010 6913030110 6905048010(Rear Right) Fitment for reference: 2001 2002 2003 2004 2005 Lexus GS430 1999 2000 2001 2002 2003 Lexus RX300 1998 1999 2000 2001 2002 2003 2004 2005 Lexus GS300 1998 1999 2000 2001 2002 Lexus GS400 2000 2001 2002 2003 2004 2005 Toyota Echo 2001 2002 2003 Toyota Prius |
Thank you. I am hoping to head to Pick n Pull in the next few days for door lock actuators. Now I need the front passenger and rear drivers side. If I have time I think I will just get them all for future.
I would advise against pick and pull as a source for door lock actuators. These parts get over used .. lock-unlock-lock-unnlock and wear out. Granted it can depend upon the programming .. driver only or all doors. And the aggravation to fix every time a failure happens is too much [imho]. Also the clips/fasteners/even-the-door-panel gets weak under stress of opening.
There is lot more effort .. replace the motor or recently fully assembled but cheap aftermarket. I would replace the motor or the part and be done for another 10 years or so. Salim |
Originally Posted by salimshah
(Post 10391249)
I just had my rear passenger actuator go out (2000 RX300 wasn’t locking/unlocking) and was able to find a pick-in-pull with a fresh vehicle on the lot. So I grabbed two complete rears with handle mechanism for $8.99 ea. I went in thinking that I would just replace the white actuator assembly from the handle connections. When it looked too tedious I just decided to replace the whole door handle with actuator assembly and found it was quite simple, and worked perfect. Unfortunately most yards don’t offer cash refunds, only credit for a defective/wrong part, but at $8.99 for functioning OEM I’m satisfied. |
Originally Posted by Audiqv8
(Post 10390968)
OE Num:
If you look at the other posts, the real answer is to just change the little motor inside the actuator.
Around $5 each on ebay and will only take you an extra 5 min. vs. changing the entire actuator. |
