Help - removing front brake disc
Salim
caseyatbt (09-22-18)
I guess it would be wise to soak it with penetrating oil before using the bolts so I don't run the risk of stripping them as well.
Chenxingha,
Once you get the rotors off, you will need to remove the rust on the hubs so the new rotors sit flat and do not wobble. Something like this will make the job easier. After rust removal, I also recommend spraying the hub face with Fluid Film to protect the new rotor from corroding and sticking to the hub. It is a thick lubricant that many who live in the snow belt swear by to reduce/prevent rusting. It is also available at Lowes and other locations.
Chenxingha,
Once you get the rotors off, you will need to remove the rust on the hubs so the new rotors sit flat and do not wobble. Something like this https://www.amazon.com/Lubricant-Corrosion-Inhibitor-11-75-oz/dp/B00PWZ0XNM]https://www.amazon.com/gp/product/B01MUA89HF [/url]
will make the job easier. After rust removal, I also recommend spraying the hub face with Fluid Film https://www.amazon.com/Lubricant-Corrosion-Inhibitor-11-75-oz/dp/B00PWZ0XNM to protect the new rotor from corroding and sticking to the hub. It is a thick lubricant that many who live in the snow belt swear by to reduce/prevent rusting. It is also available at Lowes and other locations.
Chenxingha,
Once you get the rotors off, you will need to remove the rust on the hubs so the new rotors sit flat and do not wobble. Something like this https://www.amazon.com/gp/product/B01MUA89HF
Caseyatbt:
My understanding is that the 2 small threaded holes are designed for rotor removal as a standard procedure. In my case, the 2 threads were M8 x 1.25 and both got busted when I started removing the rotor. I have M9 x 1 and M9 x 1.25 from my Tap & Die set - both are the sink-to-bottom type, not the typical long-and-pointed type. Due to the rotor still fully seated on the hub, these 2 taps may give 3 turns of threads at most. But I am unable to find M9 x 1 and M9 x 1.25 bolts in local hardware stores.
While waiting for the above Hub Removal/Install kit to arrive, I am trying with penetrant (several kinds) + hammer. The best option could be the Hub Removal/Install kit which appears to use another standard procedure - hence less stress on the other components such as bearing and housing.
This vehicle is an old vehicle of more than 18 years. It is always in the back of my mind that if I don't do things in the right way other parts could be damaged or broken easily, potentially leading to a snow balling repair job.
Try this it works great!!! https://m.youtube.com/watch?v=mtsTJCRljAs
NEVER use this method! Very well known as a great way to crack/break the ears off of the caliper mounts. Do that and you have a real problem.
This is what can happen:
https://www.clublexus.com/forums/rx-...o-replace.html
chenxingha (09-23-18)
A hub removal tool will not do anything. It has no way to apply force to the rotor.
This works great if you can find one large enough.
https://www.youtube.com/watch?v=7IQ8...ature=youtu.be
At this point you either need to get a big 3 jaw puller or BFH and use a little MAP gas to heat the rotor hat. You don't have to hit it from behind the rotor, just heat it up and get the hammer moving with some momentum. It will pop off after a few solid hits.
According to the illustration on the Hub Removal/Install set above, I can attach the tool with the hub nuts. If this doable, the hub would come off with the rotor on it and it would cost me only additional about $30 to get a new hub.
Day 3: continue to spray penetrants on the center circle and applied hammer - no movement of the rotor. Too much wind on the drive way, so touch the rotor hat is not an option for now. I am going to other stores for a sledge hammer.
