shift problems after JDM tranny replacement
Old Jul 12, 2017 | 10:33 AM
msaikhan's Avatar
msaikhan
Default shift problems after JDM tranny replacement
2002 rx300 172k AWD
so my old tranny had problems. Like, really rough shift from 2-3 and didn't go into 4. So i replaced with JDM used tranny.
Problems: ittle knock from 1-2 and 2-3, small but noticeable
C1241 code
high rpm in neutral and park
But after replacing, i'm feeling little knock from 1-2 and 2-3, small but noticeable. Also, i don't have check engine light, but did found a code. C1241 code.( doesn't seem like, it would affect tranny, maybe i can charge battery, not sure)
I did use different tranny fluid.
I'm planning on changing to toyota tranny fluid over the weekend. Hope that fixes problems.
I also read about resetting shift adapt. Do i need to reset or just drive it for a while?
Also read this. http://www.searchautoparts.com/motor...-toyota-adapts it says tranny has problems if the grounding is not good. But i can't see the pictures.
So, if changing fluid doesn't fix this, what is the next step.
Old Jul 12, 2017 | 12:33 PM
carguy07's Avatar
carguy07
I would put right fluid in it and get the battery issue taken care of before giving it anymore thought.
Old Jul 13, 2017 | 09:13 PM
hypervish's Avatar
hypervish
+1, if that doesn’t do the trick, you’ll need to get access to a Toyota techstream. It has a feature that will reset the transmission values from the computer, thereby improving performance of the replacement.
ric4044
Sep 27, 2010 10:33 PM
EzRush
Mar 3, 2010 04:43 PM
900cc
Nov 24, 2009 05:47 PM
excluesive
Oct 22, 2007 08:25 AM
SeanB
GS - 1st Gen (1993-1997)
Jul 16, 2007 09:47 AM
