99 rx300 after new transmission install
Old 04-24-17, 11:49 AM
MichaelA6
MichaelA6's Avatar
Default 99 rx300 after new transmission install
Hi guys im having some weird stuff happen with my rx300. Installed the new transmission after the old one didnt go in drive or reverse anymore.
Now im having a very rough 2000rpm idle. it comes and goes. steam is coming out of the radiator cap, New cap. getting code P1354 NOW!
i changed all the spark plugs.
i still have rough idle at 2000rpm , the steam is coming out of the cap and code p1354
Old 04-24-17, 12:04 PM
MichaelA6
MichaelA6's Avatar
also can someone please post a picture of the transmission cooling lines to the radiator
Old 04-25-17, 05:21 PM
SteveSP7
SteveSP7's Avatar
Did you try driving it? It sounds like you've either got the trans cooler in the radiator connected wrong, or you never got all the air out of the engine cooling system after reconnecting everything. Don't overheat the engine if you blow the head-gaskets that's another huge job.
Old 04-25-17, 05:54 PM
MichaelA6
MichaelA6's Avatar
okay changed the cooler lines now it's correct. The one that pours out from transmission I put it in the radiator and the other one is connect from radiator to the cooler.
Now im having yes sluggish gas and idle I have code p1354 😞
Old 04-26-17, 07:13 AM
thomas1
thomas1's Avatar
Search cleaning the Oil Control valves on the engine...Lots on this site for the p1354
Old 04-26-17, 07:59 PM
MichaelA6
MichaelA6's Avatar
did you ever fix this issue? I replaced the front one still getting a rough 2000 rpm idle and no power "gas"
Old 04-27-17, 08:11 AM
MichaelA6
MichaelA6's Avatar
ive replaced both vvt controls and still getting the rough idle what is the problem!!
qha_vn
14
11-10-15 08:35 PM
DrLex
GS - 1st Gen (1993-1997)
07-17-10 03:02 PM
lexsc3
Performance & Maintenance
08-19-03 10:50 AM
Quick Reply: 99 rx300 after new transmission install
