Window switch relay CR2-12V NAIS
Thanks dbui for the info..guess I won't cancel my order thru ali express. I hope I don't get the same runaround that rickl289 had received from some of their vendors.
http://www.aliexpress.com/item/CR2-1...9de7ae7e&tpp=1
Pricey, but it's the best I could find. It seems sellers know it's NLA and are pricing accordingly...
I came close for the cross reference relay but the pins are not on the same out put CR2-12V cross reference with ACJ5112 so close but not the same pins out put.
http://www.digikey.com/product-detai...162-ND/4756490
Rcki289,
Really, Wow nice job, can you post and share your instructions on ACJ2112 on the forums? a lot of ppl will appreciate your effort even it works for a while.
Thanks
Thanks
Not sure if this helps but I ordered the ACJ2112 and looked at each datasheet. Here is how I hooked up the new one. My sparky buddy said to glue the relay down on its back (think dead bug) where the old one was and connect wires from the pins on the relay to the board. I used 20g wire (old ATX ps wire).
Feedback
Good evening all.
Pls can someone confirm whether the ACJ5112 relay can really be used as a replacement for the Nais Cr2-12v relay. Any suggestions from those that has tried it will be highly appreciated.
Thank you.
Thank you.
Appreciation
Thank God, I was able to solve the power window issue by combination of 2 relays. After searching for cr2-12v relay without any progress, i resorted to connecting together two relays. Thanks guys for ur ideas. The windows are now working as if they are new. I could not believe that.
Hi Etoo,
If it works for you, Please posted on the DIY's forum which can help everyone with this problem.
Rickl289,
Thank you very much for the diagram which you posted.
Rickl289,
Just an update on my further attempt on getting CR2's thru Ali Express...failure....dispute ongoing to get money back. So I can then try Rickl289's above alternative or Etoo's pending alternative relay information.
wow, what a pain. Thanks for the warning.
