ClubLexus - Lexus Forum Discussion (https://www.clublexus.com/forums/)
-   RX - 1st Gen (1999-2003) (https://www.clublexus.com/forums/rx-1st-gen-1999-2003-182/)
-   -   Driver's seat position memory system failure (https://www.clublexus.com/forums/rx-1st-gen-1999-2003/802308-drivers-seat-position-memory-system-failure.html)
AlanVR Nov 3, 2015 06:14 PM
My 1999 RX300 has a failure of the driving position memory system. There is no info in the fuse list to address this item. There are no beeps when any of the 3 buttons are pushed. This failure occurred after a service by my mechanic when the coil packs and plugs were replaced. Does the control unit need to be replaced?
2KHarrier Nov 4, 2015 08:20 AM
Check these fuses;
1- 30A POWER fuse
2-10A DOME fuse
3- 15A ECU-IG fuse
Does the seat function when you adjust it? If the seat is still adjustable, it's more than likely one of these fuses. If they're all good AND the seat moves, it's more than likely the computer failed. It's located under the drivers seat. I have a good computer if you need one....
AlanVR Nov 5, 2015 11:50 AM
Thanks Harrier. My fuzes are good. How do I find the computer without disturbing the side air bag?
PM about your spare computer.
Alan
AlanVR Nov 5, 2015 02:42 PM
and yes the seat does function. Aorry about the ads that hitched a ride on my post and reply, I was using my tablet and I guess that is SOP for them...
Alan
2KHarrier Nov 5, 2015 08:15 PM
Alan
The computer is a bear to get at. The plastic cover that goes around the front of the seat has to be removed. I didn't find a way to do that successfully. The computer is mounted under the seat there, but you have to gain access from the front.
There's not a whole lot of posts on this topic, as they don't fail very often. This may sound dumb, but are you following the directions on using the memory buttons? I thought I had a problem with my wife's car, but it was user error. Hence the extra computer....
salimshah Nov 6, 2015 10:31 AM
If you really need to get at the bottom of the seat, lot easier to remove the rails and take the seat out. Just be careful about the side air bag. And also maneuvering the seat with the rails, you can damage door panel or the other seats.
Salim
AlanVR Nov 6, 2015 02:59 PM
2KHarrier
the buttons don't work at all...not even making the beep when pushed after setting the seat in the position I want to remember.
salimshah: If I can't get the seat front off with help of my bebuilder friend I will take out the seat/
Thanks guys. I'll try some kind of test before asking about the other computer. Not sure when I'll get to this...Daughter using the car most days.
Alan
