Installed full led tail lights lamps clear
4 Attachment(s)
I bought following lamp from the e-bay :http://cgi.ebay.com/ebaymotors/99-00...item25631d5cca
I installed those light today. I removed bothside (L/R) lamps upper and lower. I think almost every members know how to replace tail light bulbs. For lower lamp remove the round black plastics (red circle) and screws. Pull towards outside and it will come off. Connect new lamp with oem harnesse. For the upper lamp, pry out the inside trim and remove two screws (red circle) and at the side 2 screws (red circled) with black heads need to remove. Disconnect the harnesse (blue circle) and pull outside. |
1 Attachment(s)
Here is my stock lamp.
3 Attachment(s)
Pics of new led lamp.
3 Attachment(s)
Headlight on at day time.
looks sweet. it looks like they match your mirror signals perfectly. i had my LED tails for a couple of years and they still work fine. I only had water leak into one of them
crystal look! ..nice. are the turn signals LED too?
Turn signals are led.
makes it look way more modern in the rear!
I have a set of those cheap for you Texas/La. boys.
LED tails
The LED tails look so much better.
I installed the smoked type a few years back (IMO they look better with the black RX)...not the best pic, maybe I'll take a new one. http://members.cox.net/tony.defo/DSC04969.JPG |
[QUOTE=defo;6432184]The LED tails look so much better.
I installed the smoked type a few years back (IMO they look better with the black RX)...not the best pic, maybe I'll take a new one. Looks nicer then 2001-2003 RX300 lights :thumbup: |
Defo it looks good.
Tails look cool, man. I am having same ones installed on my Rx that is in the body shop right now after an accident. But, I must say: I like the dual exhaust. Aftermarket? or did you have it custom fab? If so what did you spend? Thanks
I bought those Delta dual exhaust from Germany.
Pretty good, but if one of those leds' go out, it's going to be a pain to replace. I'm still on the fence with this mod.
F |
