What would happen with E85?
Old Jun 22, 2010 | 09:57 PM
njb2010's Avatar
njb2010
Default What would happen with E85?
Hi,
So, I went to a gas station I normally don't go to... I don't know if I can say the name, but it's a "really great" "USA".
There were three choices of gasoline--
PREMIUM on the LEFT. E85 in the MIDDLE and REG. UNLEADED on the RIGHT
I am POSITIVE I chose the Premium, since I was being extra careful because I was at a different station.
I drove about 20 miles home. Today, it was hot, so I started it up before I was to leave. It started normally, didn't do anything abnormal. Started driving about 15 minutes later, and the RX started shaking a bit. Not a quarter mile down the road the check engine light came on. I decided to turn around, engine light went off. Turn back around, it comes on, and by this time I realize something isn't right. There is also a slight burning smell- almost the smell of a belt or something.
LONG story kinda short- ended up emptying out the tank- put in gasoline from my normal station, and was hoping things were fine. Well, it's still acting funny, engine light is still on, and it's not wanting to shift when I get up to 50mph--- so the RPMs are higher than normal.
I also had an oil change Friday... I put on 240 miles since then. Would a problem with their oil show up right away?
Any thoughts are greatly appreciated. At this point, I assume the gas might have been switched- the stuff emptied out of my tank didn't smell like normal gasoline, and had a slightly watery appearance.
Thank you for your time.
Old Jun 23, 2010 | 12:02 AM
salimshah's Avatar
salimshah
25 Year Member
Have the code read by obdI reader. Stores like Autozone do it for free.
Salim
Old Jun 23, 2010 | 03:59 AM
bob2200's Avatar
bob2200
From what I have read here on the forum, the lack of overdrive is a normal byproduct of having the Check-Engine-Light (CEL) light on. Also, you need to reset the CEL, it will not reset itself. The CEL code-reader will have a reset button, and there are several other methods.
It could just be bad premium gas, and not E85. Or, it could be something unrelated.
Mandie64
May 20, 2015 03:25 PM
ncountry
May 7, 2010 07:07 PM
tcd300
Aug 25, 2008 12:04 PM
luxury1
May 1, 2007 12:28 AM
rominl
Nov 3, 2002 01:59 AM
